27" Toshiba tv model:CX28613 chassis:TAC9215
27" Toshiba tv model:CX28613 chassis:TAC9215,year:Dec 1992,there is no
Sams photofact.I need the part # (& wattage) for R327 which reads green
then blue but the remaining two color bands are burnt,so it's either a
5.6,0.56 or 56 ohms.
I already replaced C301,C305=1 Uf,50v (brown colored Elna) and C308=220
Uf,35v and will replace IC301=TA8427K.
Other part #'s for TA8427:
IC501 in Sharp & IC301 in some Toshiba's:
Generic # TA8427
Generic # TA8427K
Generic # TA8427N
ECG Philips/NTE # NTE7158
RCA SK Thomson # TA8427K
RCA # 228444
Sharp # IX1224CEZZ
Sharp # X1224CE
Sharp # VHITA8427K\-1
Sharp # VHITA8427K/-1
Toshiba old # B0378560
Toshiba new # 23319832
Thanks in advance for the value of R327.
Sidney
Dartmouth,Nova Scotia
Canada
I
Inty
Where this resistance is employed ??? It's a resistor-fuse ??? By seeing the
traces on the PCB you can easily identify it... if it's a resistor-fuse you
can use a .56ohm or a 5.6ohm !!! If it's in another section, and isn't a
resistor fuse, you can try .56, 5.6 and 56 without blowing anything out
using a Variac !!!
I.
