I do not have an electronics background, but I will try to explain the situation as best as I can. Off of my garage I have a boiler room which houses a boiler for a driveway snowmelt system and garage heat. The system can be triggered by 2 methods. One is a roof mounted snow sensor which is currently out of commission. The other is a set of screw terminals when jumpered together turn the system on for service purposes. A few years back I ran a 2 conductor 16AWG cable from the boiler room to a switch in the house so that I could manually jump the system on. This has been working fine for years. Recently my wife complained that sometimes we forget to turn the system off after it has accomplished its task so I thought it would be a good idea to splice an indicator light into the cable to remind us when it was on. I purchased a 24 VAC LED panel mount lamp and spliced it in after the switch. When I turn the switch on tha lamp lights, but the system no longer turns on. The voltage measures 28V without the lamp. After splicing it into the cable it measures 24.5V. The only reason I brought up the wire guage and distance is I thought that the loss was possibly due to the distance (about 200') or the cable being to small. Since my initial post I have tried bypassing the cabling and simply used the leads off of the LED to jumper the screw terminal in the boiler room. The lamp again lit, but the system did not trigger. I have also tried connecting the LED to the switch in the house in parallel as you mentioned, but that did not work either. Others have mentioned changing out the relay, but that is not an option. Again I have no electronics background, so I hope what I have described is clear enough. Unfortunately at this time i would not be able to pull any additional wire between the house and boiler room, so I am looking for a solution that can use the existing cabling. Thank you for your response.
