James Lerch
Greetings All,
I built a 11.2Kw diesel generator from parts I purchased off Ebay last
year.
While running some load tests I started probing around with an O-scope
and was surprised to see how noisy the output was. In addition I was
really surprised to see the voltage across the stator. (pictures of
the O-Scope display are on the Work Day 7 & 8 page on my web address
below)
I tested the rectifier and it seems ok. I also looked at the brushes
and slip rings, both of which appear fine.
I was wondering if anyone has any ideas on why it does this and what I
could do to clean it up? If I can measure the inductance of the
stator, would adding an appropriately sized capacitor help?
For reference, here's a schematic layout on the generator:
http://www.utterpower.com/Trouble.htm
BTW, the generator works as is, but when I run it thru the 200amp
transfer switch and power my residence, the voltage drops low enough
to trigger the APC SmartUPS 1400 into running on battery while the
HVAC is running. (Line voltage drops to 107vac @ 61hz at the computer
room outlet, while I get 111vac at the generator)
The manual for the generator head discusses ways to adjust the voltage
regulation if it is too high by adding a variable resistor to the
stator winding. However, it doesn't say what to do if the voltage
output is insufficient.
My first thought was to build a new voltage regulator from scratch and
include the voltage regulation into the ATmega 128 engine rpm governor
assist project. In the mean time, I wonder if I can do anything to
assist the current situation?
Thanks for your time.
Take Care,
James Lerch
http://lerch.no-ip.com/atm (My telescope construction, Testing, and Coating site)
http://lerch.no-ip.com/ChangFa_Gen (My 11.2Kw generator project)
Press on: nothing in the world can take the place of perseverance.
Talent will not; nothing is more common than unsuccessful men with talent.
Genius will not; unrewarded genius is almost a proverb.
Education will not; the world is full of educated derelicts.
Persistence and determination alone are omnipotent.
Calvin Coolidge
year.
below)
Take Care,
James Lerch
Calvin Coolidge
