2-way mic switch with LED channel indicators
I'd love to build this idea I have - see attached sketch - but is it possible for someone like me, with with limited theory knowledge? As for practical skills, I think I could manage this sort of thing:
Hi, yes, that's right: I wish to switch one input from a 3.5mm microphone between 2 outputs.
But how to power the channel indicator LEDs? Do I need a 3PDT switch for that?
I can solder, but I have forgotten all my electronics theory. I don't know
- how to mute a mic circuit (do you just break the circuit or do you need to short it somehow?!)
- how to avoid pops/clicks
- how the PC or Mac will behave - I there to be no noise when the channel is closed, but I don't the mic to 'disappear' from the OS, for example!
Most switches use high current silver plated contacts that fail soon with the very low signal level from a microphone. Use a switch with gold plated contacts that are designed for low levels. They cost the same as switches with silver plated contacts.
Switching electret mics will cause very loud pops.
Hey Audioguru, thanks. There must be a way to avoid pops? Resistors and capacitors?
Would these components be a good starting point?
Switch
4PDT (so could have audio and indicators on separate circuits??)
https://uk.rs-online.com/web/p/toggle-switches/6925233
Indicators
https://uk.rs-online.com/web/p/indicators/0207185 Red
https://uk.rs-online.com/web/p/indicators/0209939 Blue
Enclosure
https://uk.rs-online.com/web/p/general-purpose-enclosures/5173276
emi suppression, pass it through a capacitor use a choke etc, a cleaner way would be to use a multiplayer IC chip
like the cd4051be
If you are using electret mics then they are powered with DC and will make a POP if disconnected or connected.
You could use a circuit to ramp down their signal, switch, then ramp up the signal. Do the opposite to the other mic.
why didn't I think of that
