Short version : Can I use a 2 leg female socket to charge batteries without powering the circuit?
I have a lightsaber with a soundboard. Currently it uses 2- 3.7V batteries. Removing the assembly to charge them causes a lot of wear on the wiring. So I bought a couple 2.1mm sockets to install in the hilt so I can charge without removing them. The first was intended to be installed from the inside and flush with the face of the hilt. Then I discovered there isnt enough clearance, this was a switched socket. The second I got to thread in from the outside and counterbored to be flush as well, this is a 2 legged socket. It wasnt until I already drilled and counterbored the hilt that I realized my ignorance. The other 3 leg switched socket is exactly what I needed to kill power to the circuit and charge the batteries.
Bit late now and I can't find any identical 3 leg sockets so I am wondering if I can still utilize this socket without powering the circuit and charging simultaneously by adding a couple small items to the circuit. If its possible, how can I keep it small enough to fit in a 1 inch cylinder, and what would I need?
