Brian
Jack said:I have a DC supply that says [email protected] out...
I have a DC Device that wants [email protected] in....
I know ( think ) that I can use a LM7812 to step down
the volts from 16 to 12... but the LM7812 is only rated
to 1Amp.
Also... a LM7812 says that the output varies from 11.5 - 12.5
(min 11.5, typical 12.0, max 12.5 ). I want 12.0 +- 0.2 ...
not 12.0 +- 0.5.
How is this normally handled?
Thanks - jack
Jack,
The simplest solution would be to use a LM338K regulator. If you want to
use the LM7812, you would need to use a power transistor to boost the
current, up to the 4.5 amps that you want. To do that, I drew up the
schematic for you. You can see it at http://www.fncwired.com/12VoltEx/
If you would like to go the switching regulator route, I could draw up
the schematic for that too. Let me know.
Brian
