hi I need to wire 130 leds to a 5volt supply is there a way to do this with out using 130 resistors
LED'S used
3mm
10000 mcd (ultra bright)
Forward Voltage : 3.2v – 3.8v
Forward Current : 20mA (Typical) 30mA (Max)
supply
5 volt usb
I would like to know an easy cheap but effective way to drop the voltage to 3.3 so that I can run the led's but not burn them out. prefer not to use 130 resistors as there is not a lot of room
thanks for any help you can give
(complete noob)
LED'S used
3mm
supply
5 volt usb
(complete noob)
