12v Step-down?
In looking around a bit... I believe "step-down" is the correct term.
12v automotive application. I need an adjustable "???" to step-down between 12v and 9(ish)v. Help?
The 7809 or LM317 wil do about an amp and may need a heat sink.
You can get switch mode buck convertors which are more efficient (less heat) and can provide higher currents. They may be a bit dirty and produce noise on radios.
