Can we have more details about this module and relay please?
yes sure !
what type of info do you need
the module that i modified originaly is very simple , you plug the module in youre 120v wall plug , and the other end of the module is a house 120v plug but its controled by a rj11 wire and is connected to the main module thats a climate controler
now the module that i want to modify is quite simple
perfectly normal operation of the module
120v going in , rj11 gives signal , 120v is now comming out of the module
120v goin in , rj11 gives no signal , 120v is not comming out
now my project witch is finished at 99% and looks wicked
well .. its not working well !
my project , take the 120v output of the module , and plug it to the heavy duty;s 120v voice coil
very simple , now in theory when the module receives the rj11 signal, 120v comes out of the module , the 120v now goes though the heavy duty relay turning it on and now i can plug what ever i want on the heavy duty relay like a 240v heater ! ( that was the hole ideal
everything is working as planned except when the heavy duty relay gets a signal it doesnt get a steady signal it gets a pulsing signal making it turning on and off veryy quicky ( if i plug my module like this its a fire hazard ..... my relay will end up taking fire because of high current 240v 6a , it will melt the 2 contact point in 2 min like this ... )
there must be a resistor or a capasitor i can put on the line and make it steady again ?
it must be a safe solution because example if its only a matter of a resistor to be added to the heavy duty relay's voice coil and then without me knowing burns and the relay flicker's again then its not good at all ... i rather have a system that if something like the resistor burns then the signal cannot be closed looped then the relay will never open
if i plug the relay direcly on the houses 120v it works perfectly , some how the module transfers the currents slighly alternative to extremely alternative ?
all this just to ask how to make my heavy duty relay work constant grab and not going on and off
btw this module is made and designed to be used as a heater controler
you put a 10amp or less 120v heater and it will control the room..... i wanted to put my high power relay to control my 240v heater....
if i plug a light bulb at the end of the module it will light up
my relay acts exactly like a jewelers engraver , turns on and off like 30-60 times a second like hz ?
will take pictures to show
please help me ! im sooo close to my goal !!
