Hi I have a 230 volt timed pir motion sensor supplying a 230volt trailing edge dimmer switch supplying a dimmable 230 volt to 12 volt led driver with 3 led lights drawing about 4.5watts my problem is that the dimmer will not dim the lights.
if i place the dimmer before the pir motion detector the output relay fails to latch on and and cycles on off, is this because of a lack of load although the unit specs suggest the setup should work.
any suggestions are welcome tia
