10MHz clock generator
Have a look at one of the many 10MHz crystal oscillators. They come in a metal package the size of an IC, have 4 leads, and simply require power to operate.
You'd probably be looking for one with CMOS compatible output rather than TTL.
kds, don't post multiple threads for a single question. All it achieves is getting multiple people to expend effort answering your posts and annoys the moderators.
the crystal osc that was mentioned(4 pin metal package) gave a sinusoidal types wave.
it doesnot give a exact square wave. I need it to operate ADS 805 ADC
Then use a schmitt trugger.
All the datasheets I've seen quote rise an fall times of 10 to 15 ns for the range of frequencies you want. What rise/fall time is specified as required for your ADS 805 ADC?
If your oscilloscope doesn't have a bandwidth many times (say 10 times) the frequency of the square wave you're trying to look at, then it will appear to have far slower rise and fall times.
davenn
Then use a schmitt trigger.
yup exactly I have used a 74AC14 or 74HCT14 HEX inverter(includes a schmitt trigg)
handles 10MHz easily. and if you are worried about all the harmonics up the spectrum
you can always stick in a low pass filter before the following circuitry with a cutoff of say
~ 20 or 30MHz
cheers
Dave
