1/32 brick dc-dc converter cookbook
mook johnson
http://www.murata-ps.com/newsletter/e-specifier_2012_01_26.htm
There are several companies that make the same 1/32 brick power supply
with planar transformers. I'm sure there is a appnote/cookbook or
reference designs on the design of these small supplies but I can't find
them.
In my application I cant use the commercial parts as the parts are not
rugged enough so we'd like to build a custom one.
Anyone know of a public domain reference design or appnote on making these?
Thanks.
L
legg
them.
Thanks.
I couldn't qualify these for consumer apps, at the advertised ratings,
based simply on their own thermal imaging.
What do you mean by rugged enough?
At these power densities, even the 'experts' trip over their own
salesmen.
RL
Tim Williams
Cool. First time I used planar transformers, I got about 10W through a
transformer the whole size of that module. Helps to use more than two
layers, of course. They're really pushing it, and getting only 75C temp
rise for that much power density isn't bad.
If they're getting too hot (as legg observes), they should run a hell of a
lot cooler with derating. They appear to be ceramic capacitor construction,
so they should have fine lifetime at reasonable temperatures.
Planar transformer design works like any other kind, helps to have a PCB
editor that supports and facilitates their design of course.
Tim
L
legg
Tim
One of the issues is isolation - the insulator temperature index being
limited to that of the printed wiring means there are certification
issues.
Others involve PTC of loss in ferrites (above ~85C) and fets (always).
I'd want to see two timestamped images that didn't vary appreciably.
It doesn't matter for the supply itself, if it runs cooler when
derated. It would allow use in a specific product, where suitably
derated - but thats not what you pay for in a pre-qualified
subassembly.
I expect that any certifications may specify an airflow, but I've
never done this with products that didn't generate their own....
Sticky issue.
RL
mook johnson
salesmen.
RL
I'm mainly interested in what these designs look like in the inside so I
can get an idea of how they get them so small. Our current rugedized
constructed power supply module is 10X bigger. I'd like to see if there
are any tricks they are using beside pushing components to the ragged
edge to make the supply smaller. even at 5X this size it would be a
substantial improvement in our present one.
L
legg
Rolling your own is a decision that has to be justified, in the first
place. If you can't beat them, the alternative is to use their
product. High reliability situations may even preclude the use of a
single converter. Like I said - define ruggedness.
Can you stick to telecom bus dc inputs? Safety agencies recognize
these as being isolated, so that only basic isolation is required for
SELV at the system output. This may not be important for printed
transformer winding use, but that use is a decision that needn't be
predetermined.
Second consideration is topology selection for magnetics and silicon
utilization, over the functional operating range. Unless you have
bright ideas, you're going to be using two magnetic components, with
the isolation transformer operating under reversing flux levels. You
may be able to get away with murder at lower power levels, but the
closer you get to competitive power densities, the less room there is
for the 'big semi - small heatsink' solution.
The single transformer employment in your OP showed an attempt at
resonant transfer, judging from the output ripple waveforms. This may
have worked fine for higher output voltages and lower turns ratios,
but you could see the results of trying to stretch it to low output
voltages and higher output currents.
Switched snubbing and synchronous rectification are the most common
methods of reducing size of the parts used, even for single-magnetics
type flybacks, in spite of their potential complexity. These can be
stretched and massaged for the application. There's a plethora of
literature out there covering component selection for those circuits.
RL
