Virtual GPS Engine for simulation in Proteus
February 27, 2019 by Oliver Rieder
Virtual GPS Engine for simulation in Proteus VSM.
This post describes a method for reading a text file into Proteus VSM. The text file is comprised of unprocessed GPS data that was created by traveling in a vehicle while carrying a laptop with the GPS engine connected. The data is to be used for simulation and post-processing purposes.
Raw and unparsed GPS data was sent to a text file using hyper-terminal in the laptop that was connected to the GPS engine while being transported in a moving vehicle. The data is required to be processed by Proteus Simulation software so would have to be read into Proteus VSM from the text file. From there the text file will be used to develop an algorithm for parsing and post-processing.
These components are required to perform this procedure:
Eltima’s Virtual Serial Port Driver Software (VSPD) which will be used to create virtual serial ports.
Proteus VSM Software
Visual Basic 6 code developed to read data from the text file of GPS data and transfer it to the Proteus COMPIM model.
Eltima Virtual Serial Port Driver and the Proteus COMPIM model are used to send the GPS data saved in the text file through a Visual Basic 6 program and then to the COMPIM model in the Proteus simulation.
Figure1 below shows the circuit schematic drawn in Proteus VSM:
Figure 1: Circuit Schematic
The results of a test run of this simulation are displayed in Figure 2 below:
Figure 2: Test run of the Simulation
Figure 3 is a screenshot taken from the VSPD interface that shows the creation of the virtual serial port connection.
Figure 3: Eltima Software Interface
This simulation is designed to develop code that can be used in real hardware controllers to parse and extract information from raw GPS data. We accomplish this by reading the text file into the Proteus VSM simulation software. The data is then sent to a serial port in a simulation of a micro-controller enabling us to test the code’s real-world behavior.
The Visual Basic 6 project is shown in a screenshot in Figure 4 below:
Figure 4: Screen Shot of VB project
Figure 4 provides a snapshot of the VB code for the project. The code can be linked to at:
Public Function ReadLine(fname As String, LineNumber As Long) _
     As String
  Dim oFSO As New FileSystemObject
  Dim oFSTR As Scripting.TextStream
  Dim lCtr As Long
  If oFSO.FileExists(fname) Then
     Set oFSTR = oFSO.OpenTextFile(fname)
     Do While Not oFSTR.AtEndOfStream
        lCtr = lCtr + 1
        If lCtr = LineNumber Then
            ReadLine = oFSTR.ReadLine
            Exit Do
        End If
        oFSTR.SkipLine
    Loop
     oFSTR.Close
     Set oFSTR = Nothing
   End If
 End Function
Public Function SaveTextToFile(FileFullPath As String, _
 sText As String, Optional Overwrite As Boolean = False) As _
 Boolean
On Error GoTo ErrorHandler
Dim iFileNumber As Integer
iFileNumber = FreeFile
If Overwrite Then
    Open FileFullPath For Output As #iFileNumber
Else
    Open FileFullPath For Append As #iFileNumber
End If
Print #iFileNumber, sText
SaveTextToFile = True
ErrorHandler:
Close #iFileNumber
End Function
VB6 Code 02 (File named : TextFiles.cls) :
Option Explicit
Private m_sFilePath As String
Private m_lSize As Long
Private strLines() As String
Private m_lines As Long
Public completeFile As String
Private Sub ReadFile()
m_lines = 0
Dim fso As New Scripting.FileSystemObject
    Dim ts As Scripting.TextStream
    Dim str As String
    '// Store size
    m_lSize = fso.GetFile(m_sFilePath).Size
   Dim i As Long
   i = 0
           ReDim Preserve strLines(0 To 800000) As String
    '// Get number of lines
    Set ts = fso.OpenTextFile(m_sFilePath, ForReading, False)
    While Not ts.AtEndOfStream
        str = ts.ReadLine
        i = i + 1
        strLines(i - 1) = str
        m_lines = i
        'completeFile = completeFile & str
    Wend
   completeFile = Join(strLines, vbCrLf)
    '// Close file
    ts.Close
    '// Release objects
    Set ts = Nothing
    Set fso = Nothing
End Sub
Public Property Get ReadLines(n As Long, m As Long) As String
 Dim buf As String
 buf = ""
 Dim i As Long
 For i = n To m
  If i >= n And i <= m Then
  buf = buf & strLines(i - 1) & vbCrLf
  DoEvents
  End If
  If i > m Then
  ReadLines = buf
  Exit Property
  End If
 Next
 ReadLines = buf
End Property
Public Property Get ReadLine(ByVal n As Long) As String
If n <= 0 Then n = 1
If n >= m_lines Then n = m_lines
   ReadLine = strLines(n - 1)
End Property
Public Property Let TextFilePath(ByVal pVal As String)
    m_sFilePath = pVal
    ReadFile
End Property
Public Property Get FileSize() As Long
    FileSize = m_lSize
End Property
Public Property Get NoOfLines() As Long
    NoOfLines = m_lines
End Property
Public Sub WriteNewLine(ByVal str As String)
m_lines = m_lines + 1
ReDim Preserve strLines(0 To m_lines) As String
strLines(m_lines - 1) = str
WriteFile
End Sub
Private Sub WriteFile()
    Dim i As Long
    i = 0
    Set ts = fso.OpenTextFile(m_sFilePath, ForWriting, False)
    For i = 0 To m_lines - 1
        ts.WriteLine (strLines(i))
    Next
    ts.Close
    '// Release objects
    Set ts = Nothing
    Set fso = Nothing
End Sub
Private Sub WriteFileAtPosi(ByVal str As String, ByVal posi As Long)
    Dim i As Long
    i = 0
        If (i = posi) Then
        ts.WriteLine (str)
        End If
    Next
    ts.Close
    '// Release objects
    Set ts = Nothing
    Set fso = Nothing
End Sub
Public Sub InsertNewLine(ByVal str As String, ByVal posi As Long)
    WriteFileAtPosi str, posi
    ReadFile
End Sub
Private Sub ReplaceFileAtPosi(ByVal str As String, ByVal posi As Integer)
    Dim i As Integer
    i = 0
        If (i = posi - 1) Then
        ts.WriteLine (str)
        i = i + 1
        End If
    Next
    ts.Close
    '// Release objects
    Set ts = Nothing
    Set fso = Nothing
End Sub
Public Sub ReplaceLine(ByVal str As String, ByVal LineNum As Integer)
    ReplaceFileAtPosi str, LineNum
    ReadFile
End Sub
Public Sub DeleteLines()
    Dim i As Long
    i = 0
    For i = 5000 To m_lines - 1
    Next
    ts.Close
    '// Release objects
    Set ts = Nothing
    Set fso = Nothing
ReadFile
End Sub
Oliver Rieder
I am a computer enthusiast, programmer, and electronics tinkerer. I work with PHP, MySQL, HTML, JavaScript, jQuery, CSS as well as C, Arduino.
