#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <WiFi.h>
#include <PubSubClient.h>
// Update these with values suitable for your network.
char ssid[] = "yourNetwork"; // your network SSID (name)
char pass[] = "secretPassword"; // your network password
int status = WL_IDLE_STATUS; // the Wifi radio's status
char mqttServer[] = "cloud.amebaiot.com";
char clientId[] = "amebaClientXXX"; // replace XXX with your initial to avoid Client name collision
char clientUser[] = "Your Username"; // Key in your www.amebaiot.com Username
char clientPass[] = "Your Password"; // Key in your www.amebaiot.com Password
char publishTopic[] = "outTopic";
char publishPayload[] = "thermogun ready";
char subscribeTopic[] = "inTopic";
char tempstring[] = {NULL};
char celsius[] = "*C";
#define pushbutton 2 // push button connected to pin 2
void callback(char* topic, byte* payload, unsigned int length) {
// handle message arrived
WiFiClient wifiClient;
PubSubClient client(mqttServer, 1883, callback, wifiClient);
// MLX90615 Temperature sensor setup
#define MLX90615_I2C_ADDR 0x5B // factory default address
#define MLX90615_REG_TEMP_AMBIENT 0x26
#define MLX90615_REG_TEMP_OBJECT 0x27 // 0x27 = 0b00100111, is a command, meaning reading from sensor RAM and read object temperature
float tempdata = 0;
//SSD1306 OLED display setup
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Only 4 pins are needed
#define OLED_RESET 10 //(RES)
#define OLED_MOSI 11 //(SDA)
#define OLED_DC 12 //(DC)
#define OLED_CLK 13 //(SCL)
#define OLED_CS 17 //(Not Connected)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT,
OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
#define LOGO_HEIGHT 64
#define LOGO_WIDTH 64
char appbar[] = " Ameba ";
char title[] = "ThermoGun ";
char spacer[] = " ";
static const unsigned char PROGMEM logo_bmp[] =
B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,
B00000000,B01110000,B01110000,B00000000,B00000000,B00000111,B00000111,B00000000,
B00000000,B01111001,B11110000,B00000000,B00000000,B00000111,B11001111,B00000000,
B00000000,B01111101,B11110000,B00000000,B00000000,B00000111,B11011111,B00000000,
B00000000,B01111111,B11110000,B00000000,B00000000,B00000111,B11111111,B00000000,
B00000000,B00001111,B10000000,B00000000,B00000000,B00000000,B11111000,B00000000,
B00000000,B00001111,B10000000,B00111100,B00011110,B00000000,B11111000,B00000000,
B00000000,B00001111,B11000000,B00111100,B00011110,B00000001,B11111000,B00000000,
B00000000,B00001111,B11100000,B00111100,B00011110,B00000011,B11111000,B00000000,
B00000000,B00001111,B11110000,B00111100,B00011110,B00000111,B11111000,B00000000,
B00000000,B00000111,B11111000,B00011000,B00001100,B00001111,B11110000,B00000000,
B00000000,B00000011,B11111100,B00001000,B00001100,B00011111,B11100000,B00000000,
B00000000,B00000001,B11111110,B00001000,B00001100,B00111111,B11000000,B00000000,
B00000000,B00000000,B11111110,B00001000,B00001100,B00111111,B10000000,B00000000,
B00000000,B00000000,B01111110,B00001000,B00001100,B00111111,B00000000,B00000000,
B00000000,B00000000,B01111110,B00001111,B11111100,B00111111,B00000000,B00000000,
B00000000,B00000000,B01111110,B00000000,B00000000,B00111111,B00000000,B00000000,
B00000000,B00000000,B01111111,B11110000,B00000111,B11111100,B00000000,B00000000,
B00000000,B00000000,B00111111,B11111000,B00001111,B11111100,B00000000,B00000000,
B00000000,B11111111,B10111111,B11111100,B00011111,B11111101,B11111111,B00000000,
B00000001,B11000000,B00111111,B11111110,B00111111,B11111100,B00000011,B00000000,
B00000001,B10000000,B00111111,B11111111,B00111111,B11111000,B00000001,B10000000,
B00000011,B00011111,B10110000,B11111111,B11111110,B00000001,B11111000,B11000000,
B00000110,B00111111,B00111111,B11111111,B11111110,B00000001,B11111100,B01100000,
B00000110,B01110000,B00111111,B11111111,B11111110,B00000000,B00001110,B01100000,
B00000100,B11100000,B00111111,B11111011,B11101110,B00000000,B00000110,B00100000,
B00000100,B11000111,B10111011,B11111001,B11001110,B00000001,B11110011,B00100000,
B00000100,B10001111,B00110001,B11111000,B10001110,B00000000,B11110011,B00100000,
B00000100,B10011000,B00110001,B11111000,B00001110,B00000000,B00011001,B00100000,
B00000100,B10010001,B10110001,B11111000,B00001110,B00000001,B10001101,B00100000,
B00000100,B10010011,B10110000,B11111000,B00001111,B00000001,B11001101,B00100000,
B00000000,B10010010,B00110000,B11111000,B00001111,B11111000,B01001101,B00000000,
B00000000,B00010010,B00000000,B00000000,B00000000,B00000000,B01001100,B00000000,
B00000000,B00000010,B00000000,B00000000,B00000000,B00000000,B01000000,B00000000,
B00111111,B10000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,
B00111001,B11000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,
B00111000,B11000111,B11100000,B10000001,B10000111,B11110011,B11100011,B00001000,
B00011000,B11100110,B00000000,B11000001,B10000001,B11000011,B00000011,B00010000,
B00011000,B11000110,B00000001,B11000001,B10000000,B11000011,B00000011,B00100000,
B00011001,B11000110,B00000001,B11000001,B10000000,B11000011,B00000011,B01000000,
B00011111,B00000110,B00000000,B01100001,B10000000,B11000011,B00000011,B01000000,
B00011011,B00000111,B11000010,B01100001,B10000000,B11000011,B11100011,B11000000,
B00011011,B10000110,B00000011,B11110001,B10000000,B11000011,B00000011,B11100000,
B00011001,B11000110,B00000110,B00110001,B10000000,B11000011,B00000011,B01100000,
B00111001,B11000110,B00000100,B00110001,B10000000,B11000011,B00000011,B00110000,
B00111000,B11100110,B00001000,B00011001,B10000000,B11000011,B00000011,B00111000,
B00011000,B01100111,B11101000,B00011001,B11111000,B10000011,B11100011,B00011000,
char *dtostrf (double val, signed char width, unsigned char prec, char *sout) {
char fmt[20];
sprintf(fmt, "%%%d.%df", width, prec);
sprintf(sout, fmt, val);
return sout;
float get_temp(){
uint16_t data;
Wire.beginTransmission(MLX90615_I2C_ADDR);
Wire.write(MLX90615_REG_TEMP_OBJECT);
Wire.endTransmission(false); // false is to instruct i2c NOT to send a STOP bit
Wire.requestFrom(MLX90615_I2C_ADDR, 2); // read 3 bytes of data
data = Wire.read(); // 1st byte is LSB
data|= Wire.read() << 8; // 2nd byte is MSB
//Wire.read(); // 3rd byte is PEC, which is not of our interest here. This line is just to exhaust i2c buffer
// Serial.println();
// Serial.print("Data received is: ");
// Serial.println(data);
// Serial.println(data,BIN);
return tempdata = data * 0.02 - 273.15; //raw temperateu data requires conversion to celsius
void setup() {
char counter = 2;
Serial.begin(9600);
Wire.begin();
pinMode(pushbutton,INPUT); // push button on pin 2
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if(!display.begin(SSD1306_SWITCHCAPVCC)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
drawbitmap(); // Draw a logo bitmap image
while ( (status != WL_CONNECTED) && (counter > 0) ) {
// only attempt WiFi connection twice then bypass wifi
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 5 seconds for connection:
delay(5000);
counter--;
if (status != WL_CONNECTED) {
display.clearDisplay();
display.setTextSize(2);
display.setTextColor(SSD1306_WHITE);
display.println();
display.println(F("WiFi fail"));
display.println(F("Init MQTT"));
display.display();
} else {
display.println();
display.println(F("WiFi contd"));
display.display();
if (client.connect(clientId, clientUser, clientPass)) {
client.publish(publishTopic, publishPayload);
client.subscribe(subscribeTopic);
//Display ThermGun interface after all init is done
interface();
void loop() {
while(digitalRead(pushbutton)) {
tempdata = get_temp();
Serial.print(" Object= ");
Serial.print(tempdata);
Serial.println(" *C");
dtostrf(tempdata,4,2,tempstring);
strcat(tempstring, celsius);
client.publish(publishTopic, tempstring);
interface();
client.loop();
void interface(void) {
display.setTextSize(1); // Normal 1:1 pixel scale
display.setTextColor(SSD1306_BLACK, SSD1306_WHITE); // Draw 'inverse' text
display.setCursor(0,0); // Start at top-left corner
display.println(appbar);
display.println(title);
display.println(spacer);
display.println();
// display.setTextSize(1);
// display.setTextColor(SSD1306_WHITE);
// display.println(F("Temperature:"));
// display.println();
display.setTextSize(2); // Draw 2X-scale text
display.print(tempdata);
display.println(F(" C"));
display.display();
delay(1000);
void drawbitmap(void) {
display.drawBitmap(
(display.width() - LOGO_WIDTH ) / 2,
(display.height() - LOGO_HEIGHT) / 2,
logo_bmp, LOGO_WIDTH, LOGO_HEIGHT, 1);
display.display();
