Clone USB Key - Software solution
December 09, 2019 by Oliver Rieder
How to share USB Dongle over network. Multiconnect for Dongle.
A dongle is a peripheral device that is plugged into the open port of your laptop/computer to help you transfer the important to a place that is much secure. Securing the important files of your organization is very important and using, a dongle that is an essential device, which helps you to protect your important data.
However, there are times when you need to give the copies of those files to your employee for that reason it is important to know how to make protected copies of your file, which would permit the users to access the document through validation as this will allow the employees to view the data or make modification if necessary. Also, it is important to create copies of dongle just in case the device got damaged so you can recover the files easily.
Here is a complete guide for you to know what dongle is? How it is supposed to work and how you can make copies to secure your files?
What is a USB Dongle and what it does?
A dongle is an adapter that connects to the computer to secure and protect the files and also performs the function to authenticate the user of the device.
Here is how a dongle works; when a programing function starts, it reaches for the dongle to attain the security code to proceed with its operation.
Making a duplicate of the Dongle
The most suitable and apt way to replicate a dongle or security key is a software called Doglify. Special software that will let you share the dongle to other networks. Donglify eliminates the necessity of any additional hardware device to share dongles across networks. It enables the dongle to work implicitly so that it can be accessed remotely to any computer that is not even connected to it. Donglify provides a secure method to single-handedly duplicate software and allows access to over a network.
USB Dongles can be duplicated in following ways through Donglify:
The unique feature Multiconnect allows the users to use USB dongles to make copies for more than one computer at the same time. This function is currently accessible only for HASP HL ​​Pro, Sentinel HL Pro, SafeNet eToken 5110, and CodeMeter CmStick security keys.
Oliver Rieder
I am a computer enthusiast, programmer, and electronics tinkerer. I work with PHP, MySQL, HTML, JavaScript, jQuery, CSS as well as C, Arduino.
