How to Connect the STM32 “Blue Pill" to a 16x2 LCD Module
September 24, 2019 by Reginald Watson
Learn how to interface the STM32 Blue Pill with a 16x2 character LCD module using Arduino IDE.
The STM32F103C8T6 module, also known as the Blue Pill module, is a very pocket-friendly alternative to the Arduino. In projects where you want to use a lot of cheap boards, these boards come in handy.
I previously covered the basics of getting started with the Blue Pill module, which showed you how to integrate the board into Arduino IDE. Check out that article before proceeding to this tutorial.
In this tutorial, I will show you to set up the Blue Pill with a 16x2 character LCD, which can be used in a variety of your projects.
What are LCDs?
LCDs are probably the most popular visual feedback devices used in projects. Whether you’re building an MP3 player project and want to show the name of the track being played or creating a quadcopter console that displays flight telemetry, this tutorial will come in handy for working with the Blue Pill.
16x2 character lcd module
The LCD module used in this tutorial.
In addition to 16x2, you can find 20x4 character displays (four lines of 20 characters each). Green-black and blue-white are the most popular colors for these displays. There are also other variants that have a graphic display with a resolution of 128x64 pixels.
128x64 lcd graphic display
An example of a 128x64 pixel LCD graphic display.
16x2 Character LCD Pinout
This character 16X2 LCD has 16 pins, shown in the diagram and table below.
lcd module pinout
LCD module pinout
Pin
Name
Function
Description
1
Vss
Power
GND
2
Vdd
Power
+ 5V
3
Vee
Contrast Adj.
(-2) 0-5V
4
RS
Command
Register Select
5
R/W
Command
Read/Write
6
E
Command
Enable (strobe)
7
D0
I/O
Data LSB
8
D1
I/O
Data
9
D2
I/O
Data
10
D3
I/O
Data
11
D4
I/O
Data
12
D5
I/O
Data
13
D6
I/O
Data
14
D7
I/O
Data MSB
We will only be using 10 pins from this set to interface with our Blue Pill board. if you want to explore more about these LCD displays, check out How to Connect an LCD Display to Your Arduino.
Hardware Requirements
  • 16×2 LCD display
  • FTDI Programmer
  • STM32 Blue Pill Development Board
  • Jumper wires
  • Breadboard
FTDI programmer
FTDI programmer
stm32 blue pill
STM32 "Blue Pill"
Hardware Connections
Wire up the hardware as shown in the diagram below.
Connecting the STM32 to the FTDI programmer.
Connecting the LCD module to the STM32.
Use the connections table below to help guide you along with the Fritzing diagrams above.
LCD Pin Number
LCD Pin Name
STM32 Pin Name
1
GND
Ground (G)
2
Vcc
5V
3
Vee
Ground (G)
4
Register Select (RS)
PB11
5
Read/Write (R/W)
Ground (G)
6
Enable (EN)
PB10
7
DB0
No Connection
8
DB1
No Connection
9
DB2
No Connection
10
DB3
No Connection
11
DB4
PB0
12
DB5
PB1
13
DB6
PC13
14
DB7
PC14
15
LED Positive
5V
16
LED Negative
Ground (G)
the connected project
The hardware all connected.
Uploading the Code Into Arduino IDE
You will need a USB to UART converter for connecting this board to the Arduino. Again, the steps for hooking that up can be found in detail in Getting Started With the Blue Pill.
set the stm32 controller to DFU mode by placing the jumper as shown
Copy the code found in a Zip file at the end of the article into Arduino IDE and, before uploading the program, make sure that the boot 0 jumper is set to 1 as shown in the image below. Then press the reset button.
Reginald Watson
