Connect an IR remote to your project using Arduino!
#include <IRremote.h>
#include <LiquidCrystal.h>
#define PIN_RECEIVER 2 // Signal Pin of IR receiver
IRrecv receiver(PIN_RECEIVER);
LiquidCrystal lcd(12, 11, 10, 9, 8, 7);
void setup()
lcd.begin(16, 2);
lcd.print("<press a button>");
receiver.enableIRIn(); // Start the receiver
void loop()
// Checks received an IR signal
if (receiver.decode()) {
translateIR();
receiver.resume(); // Receive the next value
void lcdPrint(char* text)
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("button pressed:");
lcd.setCursor(0, 1);
lcd.print(text);
lcd.print(" code: ");
lcd.print(receiver.decodedIRData.command);
void translateIR()
// Takes command based on IR code received
switch (receiver.decodedIRData.command) {
case 162:
lcdPrint("POWER");
break;
case 226:
lcdPrint("MENU");
break;
case 34:
lcdPrint("TEST");
break;
case 2:
lcdPrint("PLUS");
break;
case 194:
lcdPrint("BACK");
break;
case 224:
lcdPrint("PREV.");
break;
case 168:
lcdPrint("PLAY");
break;
case 144:
lcdPrint("NEXT");
break;
case 104:
lcdPrint("num: 0");
break;
case 152:
lcdPrint("MINUS");
break;
case 176:
lcdPrint("key: C");
break;
case 48:
lcdPrint("num: 1");
break;
case 24:
lcdPrint("num: 2");
break;
case 122:
lcdPrint("num: 3");
break;
case 16:
lcdPrint("num: 4");
break;
case 56:
lcdPrint("num: 5");
break;
case 90:
lcdPrint("num: 6");
break;
case 66:
lcdPrint("num: 7");
break;
case 74:
lcdPrint("num: 8");
break;
case 82:
lcdPrint("num: 9");
break;
default:
lcd.clear();
lcd.print(" other button");
Learn how to add IR(infrared) remote to your Arduino projects. I am using a free Arduino simulator to demonstrate it. Let's begin!!!
Section Header
Explain each section of your project
Arduino IR remote project on Wokwi Arduino Simulator
Introduction
It is so easy to add IR remote to your projects. In this tutorial, I will show you how to easily add an IR remote and an IR receiver for your next Arduino project. I am using a free Arduino simulator to demonstrate IR receiver and IR remote projects.
Components needed
- Arduino Nano (Arduino UNO) can also be used
- IR receiver
- IR transmitter (IR Remote)
- LCD (optional, to display the pressed key information)
The connection diagram/wiring diagram for IR receiver, IR remote and Arduino
IR remote Arduino Simulator
Arduino Code
void setup()
lcd.begin(16, 2);
void loop()
translateIR();
lcd.clear();
lcd.print(text);
void translateIR()
case 162:
lcdPrint("POWER");
break;
case 226:
lcdPrint("MENU");
break;
case 34:
lcdPrint("TEST");
break;
case 2:
lcdPrint("PLUS");
break;
case 194:
lcdPrint("BACK");
break;
case 224:
lcdPrint("PREV.");
break;
case 168:
lcdPrint("PLAY");
break;
case 144:
lcdPrint("NEXT");
break;
case 104:
lcdPrint("num: 0");
break;
case 152:
lcdPrint("MINUS");
break;
case 176:
lcdPrint("key: C");
break;
case 48:
lcdPrint("num: 1");
break;
case 24:
lcdPrint("num: 2");
break;
case 122:
lcdPrint("num: 3");
break;
case 16:
lcdPrint("num: 4");
break;
case 56:
lcdPrint("num: 5");
break;
case 90:
lcdPrint("num: 6");
break;
case 66:
lcdPrint("num: 7");
break;
case 74:
lcdPrint("num: 8");
break;
case 82:
lcdPrint("num: 9");
break;
default:
lcd.clear();
IR remote basics
There is a wonderful article here on Adafruit learning page
https://learn.adafruit.com/ir-sensor/ir-remote-signals
Another resource I found which is helpful
https://www.circuitbasics.com/arduino-ir-remote-receiver-tutorial/
Support and any feedback?
Please hop on to the Discord channel for any suggestions or comments. You can visit the Arduino simulator home page.
More projects here: https://www.wokwi.com
