TICO - Open Source Tic-Tac-Toe Arduino Robot
September 18, 2021 by Mirko Pavleski
This is an Arduino-powered Tic-Tac-Toe robot, which will provide you an excellent game experience.
Hardware
Software
1 Arduino IDE
Tools
1 Soldering iron (generic)
1 Solder Wire, Lead Free
This time I will show you how to make an Arduino-powered Tic-Tac-Toe robot, which will provide you an excellent game experience.
Visit my sponsor PCBgogo for all your PCB needs, 10% OFF NOW!
https://www.pcbgogo.com/promo/from_MirkoPavleskiMK
The game is played on a small whiteboard that is covered with transparent packing tape that will make it very easy to erase the board between games. For better visual effect, communication with the robot is done through a small TFT color screen.
This is an Open Source project called "TICO – Tic-Tac-Toe Arduino Robot" and detailed documentation can be found on the author's website:
https://playrobotics.com/blog/tico-tic-tac-toe-arduino-robot-documentation/
If you decide to make it yourself, share your questions and join the conversation on the Tico Facebook group:
https://www.facebook.com/groups/890278848555627
Unlike the original design, I made the mechanical part from a PVC board with a thickness of 3 mm which I processed with a scalpel.
In fact, I made this part for one of my previous videos that described a project called "Plotlock", when I still did not have a 3D Printer. The initial design of Tico was inspired by this Plotclock project, and Parts of the Plot clock’s code is used in Tico’s code. Of course, it is much better and easier to make if you have a 3D Printer, and.stl files are given on the page.
The game starts when the robot clears the board first, then draws the frame and marks the first move. After that, the human player marks his move on the board, and also on the remote controller, or on the Arduino serial monitor depending on the settings in the code. When someone wins, the robot marks it on the board and on the screen with a message.
The electronic part of the device is very simple to build and consists of several components:
- Arduino Uno microcontroller
- Three cheap 9 grams servo motors
- 1.8 inch TFT color display
- Buzzer
-button
- and Ifra Red receiver.
We will first show the case when we enter our moves through the Arduino serial monitor. To do this, we need to modify the next line of code:
#define SERIAL_MONITOR_MODE true
The robot can also mark our moves. It is given through the section:
#define DRAW_HUMAN_MOVE true
If we want to enter our moves with Remote Controller we need to make the following code modification:
#define SERIAL_MONITOR_MODE false
To find out the codes specifically for your remote controller, I made a small program that you can also download at the link provided.
As you can see in the video the Robot can not boast of any great Intelligence, but this is an Open Project and I hope that in the future that part will be improved.
// Tico - Tic-Tac-Toe playing robot
// Tico is an open source 3D printed robot designed by PlayRobotics
// Tico was designed in order to inspire kids to learn coding while teaching Tico to play Tic-Tac-Toe
// Full documentation can be found here: https://playrobotics.com/blog/tico-tic-tac-toe-arduino-robot-documentation
// Attribution: Parts of this code are based on the popular Plotclock by Joo (https://www.thingiverse.com/thing:248009)
//Should playro draw the move made by the human, or the human will draw it himself?
#define DRAW_HUMAN_MOVE false
//If you don't have a remote control or IR receiver you can enable serial monitor instead
//When using serial monitor please choose 'No line ending' from the dropdown next to the boundrate instead of 'new line'
// Include libraries
#include <Wire.h>
#include <Servo.h>
#include <IRremote.h>
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library for ST7735
#include <SPI.h>
// Servo pins
const int LEFT_SERVO_PIN = 7;
const int RIGHT_SERVO_PIN = 6;
const int LIFT_SERO_PIN = 5;
Servo servo_lift;
Servo servo_left;
Servo servo_right;
//LCD Pins
#define TFT_CS        10
#define TFT_RST        8 // Or set to -1 and connect to Arduino RESET pin
#define TFT_DC         9
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
// Lift servo calibration
// *** If the pen is not touching the board, this is the value you should play with ***
const int Z_OFFSET = 395;  // Lower value will lift the pen higher
//*** Other servo configurations, usually you will not need to touch those
int servoLift = 1500;
const int LIFT0 = 1110 + Z_OFFSET;  // On drawing surface
const int LIFT1 = 925 + Z_OFFSET;   // Between numbers
const int LIFT2 = 735 + Z_OFFSET;   // Going towards sweeper
const int LIFT_SPEED = 1000;  // Speed of liftimg arm, lower number will increase speed.
// Side servos calibration
const int SERVO_LEFT_FACTOR = 690;
const int SERVO_RIGHT_FACTOR = 690;
// Zero-position
const int SERVO_LEFT_NULL = 1950;
const int SERVO_RIGHT_NULL = 815;
// Length of arms
const float L1 = 35;
const float L2 = 55.1;
const float L3 = 13.2;
const float L4 = 45;
// Origin points of left and right servos.
const int O1X = 24;
const int O1Y = -25;
const int O2X = 49;
const int O2Y = -25;
// Home coordinates, where the eraser is.
const volatile double ERASER_X = -11;
const volatile double ERASER_Y = 45.5;
volatile double lastX = ERASER_X;  // 75;
volatile double lastY = ERASER_Y;  // 47.5;
//We will be using an array that will hold the current state of all our game cells
// -1-> Empty cell
// 0 -> 0
// 1 -> X
int board_values[] = { -1, -1, -1, -1, -1, -1, -1, -1, -1};
int empty_places = 9;
int winner = -1;
void setup()
  Serial.begin(9600);
  //LCD Setup and clear
  tft.initR(INITR_BLACKTAB);
  tft.fillScreen(ST77XX_BLACK);
  //Play sound on start
  tone(4,3000,250);
  delay(250);
  tone(4,400,250);
  delay(250);
  tone(4,3000,250);
  delay(250);
  //Draw blinking eyes animation
  tft.fillCircle(30, 50, 25, ST77XX_BLUE);
  tft.fillCircle(95, 50, 25, ST77XX_BLUE);
  delay(500);
  tft.fillCircle(30, 50, 15, ST77XX_BLACK);
  tft.fillCircle(95, 50, 15, ST77XX_BLACK);
  delay(500);
  tft.fillCircle(30, 50, 15, ST77XX_BLUE);
  //tft.fillCircle(95, 50, 15, ST77XX_BLUE);
  delay(250);
  //tft.fillCircle(95, 50, 15, ST77XX_BLACK);
  delay(250);
  //tft.fillCircle(30, 50, 25, ST77XX_BLUE);
  delay(250);
  //tft.fillCircle(30, 50, 15, ST77XX_BLACK);
  delay(250);
  delay(250);
  delay(1000);
  tft.setCursor(0, 0);
  tft.setTextColor(ST77XX_WHITE);
  tft.setTextSize(2);
  tft.setTextWrap(true);
  tft.setCursor(30, 90);
  tft.setTextColor(ST77XX_BLUE );
  tft.setTextSize(3);
  tft.print("I'M");
  tft.setCursor(30, 120);
  tft.print("TICO");
  //Play sound when LCD says "I'M Tico"
  tone(4,400,250);
  delay(250);
  tone(4,3000,250);
  delay(250);
  delay(500);
  //Setup IR reciver on Pin 2
  IrReceiver.begin(2);
  //This is needed because we want different random number every time Arduino is reastrted
  randomSeed(analogRead(A2));
  pinMode(4, OUTPUT);
  pinMode(A0, INPUT_PULLUP);
void loop()
  // Draw "Click Start" message
  tft.setCursor(30, 100);
  tft.fillRect(0,90,130,100,ST77XX_BLACK);
  tft.setTextColor(ST77XX_YELLOW );
  tft.setCursor(20, 90);
  tft.print("Click");
  tft.setCursor(20, 120);
  tft.print("Start");
  tone(4,3000,250);
  delay(250);
  //The loop will run over and over again until the game is started
  //The game can be started using a button or serial monitor if you don't have a button
  //SERIAL-MONITOR-MODE setting can be changed in the begning of this code
  if (SERIAL_MONITOR_MODE)
    //Serial monitor start
     //Print main menu
    Serial.println("--==MAIN MENU==--");
    Serial.println("==S== Start Game");
    Serial.println("==E== Erase");
    Serial.println("==F== Draw Frame");
    Serial.println("==H== Go Home");
    //We just wait until there is an input
    while (Serial.available() == 0) {}
    //Get the value user entered
    int user_input = Serial.read();
    //Ignore the hidden line end character the monitor is adding to the received character
    if(user_input != '\n')
      //React to user input
      if ((user_input!='S')&&(user_input!='E')&&(user_input!='F')&&(user_input!='H')&&(user_input!='s')&&(user_input!='e')&&(user_input!='f')&&(user_input!='h'))
        Serial.println("====WRONG INPUT====");
      else
       if ((user_input=='H')||(user_input=='h'))
            goHome();
       else
          if ((user_input=='E')||(user_input=='e'))
            erase();
            //goHome();
          else
            if ((user_input=='F')||(user_input=='f'))
              drawFrame();
            else
              startGame();
  else
    //Button start
    //The following loop will just continue until the button is pressed
    int button_value = analogRead(A0);
    while(button_value<500)
      delay(20);
      //If you are using a regular button it will also require a pull up resistor
      //Alternatively you can use an  "Arduino button moudle" that already has a built in resistor
      //Another option will be to use Arduin's built in pull-up resistor
    startGame();
  //Reset game variables before next game
  //Winner can be: 0 , 1(X) or 2(tie)
  winner = -1;
  empty_places = 9;
  //This array holds all the moves
  // 1->empty 0->0 1->X
  //Going over it to make it empty
  for (int i = 0; i < 9; i++)
    board_values[i] = -1;
void startGame()
  Serial.println("====GAME IS ON====");
  tone(4,3000,250);
  //Clean text area
  //Print
  tft.print("GAME");
  tft.setCursor(20, 115);
  tft.print("=IS=");
  tft.setCursor(20, 140);
  tft.print("=ON= ");
  delay(500);
  Serial.println("Erasing");
  erase();
  Serial.println("Drawing Frame");
  drawFrame();
  delay(1000);
  Serial.println("Tico is making the first move");
  drawMove(5);
  recordMove(5);
  //As long as the game is runing we need to repeate this loop
  while ((winner == -1) && (empty_places > 0))
    Serial.println("Human, enter your move(1-9)");
    tft.setTextColor(ST77XX_RED);
    //Clean text area
    //Print
    tft.print("YOUR");
    tft.print("MOVE");
    int moveTo;
    tft.fillCircle(30, 50, 15, ST77XX_RED);
    //This mode can be used to get input from user via monitor instead of remote control
    //You can change this setting at the beggining of this code
        //Serial monitor mode
        //This loop will just wait until there is an input
        moveTo = Serial.readString().toInt(); //Reading the Input string and turning it to integer
    else
        //IR mode
        IrReceiver.enableIRIn();
        delay(100);
        int code_received = false;
        while (!code_received)
          detachServos();
          if (IrReceiver.decode())
            // Print a short summary of received data
            IrReceiver.printIRResultShort(&Serial);
            //Mapping of codes sent by the remote control we are using,
            //if you are using a different remote control you will need to re-map this
            //0x4 ->1
            //0x5 ->2
            //0x6 ->3
            //0x8 ->4
            //0x9 ->5
            //0xA ->6
            //0xC ->7
            //0xD ->8
            //0xE ->9
            IrReceiver.resume(); // Enable receiving of the next value
            int message_rec = IrReceiver.decodedIRData.command;
            if ((message_rec == 0xC) || (message_rec == 0x18) || (message_rec == 0x5E)
                || (message_rec == 0x8) || (message_rec == 0x1C) || (message_rec == 0x5A)
                || (message_rec == 0x42) || (message_rec == 0x52) || (message_rec == 0x4A))
              code_received = true;
              IrReceiver.disableIRIn();
              if (message_rec == 0xC)
                moveTo = 1;
              if (message_rec == 0x18)
                moveTo = 2;
              if (message_rec == 0x5E)
                moveTo = 3;
              if (message_rec == 0x8)
                moveTo = 4;
              if (message_rec == 0x1C)
                moveTo = 5;
              if (message_rec == 0x5A)
                moveTo = 6;
              if (message_rec == 0x42)
                moveTo = 7;
              if (message_rec == 0x52)
                moveTo = 8;
              if (message_rec == 0x4A)
                moveTo = 9;
          delay(30);
    //***Regardless of the mode that was used(serial / IR)
    //we now have the user's move in moveTo variable
    //Check if the move value is valid
    if ((moveTo > 0) && (moveTo < 10))
      //Check if this place is still empty
      if (board_values[moveTo - 1] == -1)
        Serial.print("Moving to: ");
        Serial.println(moveTo);
        //Only draw the move made by the user if this setting is activated
        if (DRAW_HUMAN_MOVE)
          drawMove(moveTo + 10);
        //Even if Tico didn't draw the move he should document it anyway
        recordMove(moveTo + 10);
        checkWinnerRow (1, 0);
        checkWinnerRow (2, 0);
        checkWinnerRow (3, 0);
        checkWinnerCol (1, 0);
        checkWinnerCol (2, 0);
        checkWinnerCol (3, 0);
        checkWinnerDiag (1, 0);
        checkWinnerDiag (2, 0);
        if ((winner == -1) && (empty_places > 0))
          //Clean text area
          //Print
          tft.print("TICO");
          tft.print("MOVE");
          tft.fillCircle(95, 50, 15, ST77XX_YELLOW);
          replyMove();
        checkWinnerRow (1, 1);
        checkWinnerRow (2, 1);
        checkWinnerRow (3, 1);
        checkWinnerCol (1, 1);
        checkWinnerCol (2, 1);
        checkWinnerCol (3, 1);
        checkWinnerDiag (1, 1);
        checkWinnerDiag (2, 1);
      else
        Serial.println("Already taken!!");
        //IrReceiver.disableIRIn();
        //delay(100);
        //Clean text area
        //Print
        tft.print("PLACE");
        tft.print("TAKEN");
        tone(4, 1000, 250);
        delay(250);
    }//End if -> Check if the move value is valid
  }//End if -> Check if this place is still empty
  goHome();
void checkWinnerCol (int col, int player) {
  //Row
  if ((board_values[(col - 1) * 3] == player) && (board_values[(col - 1) * 3 + 1] == player) && (board_values[(col - 1) * 3 + 2] == player))
    attachServos();
    Serial.println("--== Winner COL==--");
    Serial.println(player);
    if (player==0){
        //tft.print("==YOU====WIN==");
        //Clean text area
        //Print
        tft.print("=YOU=");
        tft.print("=WIN=");
    else
        //tft.print("==TICO===WINS==");
        tft.setTextColor(ST77XX_BLUE);
        //Clean text area
        //Print
        tft.print("TICO");
        tft.print("WINS!");
    drawTo(55 - 20 * (4 - col - 1), 10);
    //Draw
    lift(LIFT0);
    drawTo(55 - 20 * (4 - col - 1), 50);
    lift(LIFT2);
    winner = player;
void checkWinnerRow (int row, int player) {
  //Row
  if ((board_values[row - 1] == player) && (board_values[row + 3 - 1] == player) && (board_values[row + 6 - 1] == player))
    attachServos();
    Serial.println("--== Winner ROW==--");
    tft.setCursor(0, 20);
    if (player==0){
        //Clean text area
        //Print
        tft.print("=YOU=");
        tft.print("=WIN=");
    else
        //Clean text area
        //Print
        tft.print("TICO");
        tft.print("WINS!");
    drawTo(10, 43 - 14 * (row - 1));
    //Draw
    lift(LIFT0);
    drawTo(60, 43 - 14 * (row - 1));
    lift(LIFT2);
    winner = player;
void checkWinnerDiag (int diag, int player) {
  attachServos();
  //Check which diagonal
  if (diag == 1)
    if ((board_values[1 - 1] == player) && (board_values[5 - 1] == player) && (board_values[9 - 1] == player))
      Serial.println("--== Winner DIAGONAL 1==--");
      if (player==0){
        //Clean text area
        //Print
        tft.print("=YOU=");
        tft.print("=WIN=");
      else
        //tft.print("==TICO===WIN==");
        //Clean text area
        //Print
        tft.print("TICO");
        tft.print("WINS!");
      drawTo(60, 10);
      //Draw
      lift(LIFT0);
      drawTo(15, 45);
      lift(LIFT2);
      winner = player;
  else
    if ((board_values[7 - 1] == player) && (board_values[5 - 1] == player) && (board_values[3 - 1] == player))
      Serial.println("--== Winner DIAGONAL 2==--");
      if (player==0){
        //Clean text area
        //Print
        tft.print("=YOU=");
        tft.print("=WIN=");
      else
        //Clean text area
        //Print
        tft.print("TICO");
        tft.print("WINS!");
      drawTo(10, 10);
      //Draw
      lift(LIFT0);
      drawTo(60, 50);
      lift(LIFT2);
      winner = player;
      // or draw the line from other side
        drawTo(60, 45);
        //Draw
        lift(LIFT0);
        drawTo(15, 10);
        lift(LIFT2);
void replyMove() {
  //========= Reply move ======
  //We will generate a random number from 1 to the number of empty places
  //We will then go over the array and count the empty places we meet until we get to the needed place
  //If there are 3 empty places and the trandom number will be 2 , this means we will make a move at the second empty place we find
  int randEmptyPlace = random(empty_places) + 1;
  //Debugging
    Serial.println("============================");
    Serial.print("Empty Spaces:");
    Serial.println(empty_places);
    Serial.print("Replying to randEmptyPlace: ");
    Serial.println(randEmptyPlace);
  //Loop until we find an empty place
  int emptyPlacesFound = 0;
    if (board_values[i] == -1)
      //We found an empty place
      emptyPlacesFound++;
      if (emptyPlacesFound == randEmptyPlace)
        drawMove(i + 1);
        recordMove(i + 1);
        Serial.print("Replying to: ");
        Serial.println(i + 1);
void recordMove(int move)
  if ((move >= 1) && (move <= 9))
    board_values[move - 1] = 1;
    empty_places--;
  if ((move >= 11) && (move <= 19))
    board_values[move - 11] = 0;
    empty_places--;
void drawMove(int move)
  attachServos();
  switch (move) {
    case 0:
      drawFrame();
      break;
    case 1:
      drawX(15, 40);
      break;
    case 2:
      drawX(15, 25);
      break;
    case 3:
      drawX(15, 10);
      break;
    case 4:
      drawX(30, 40);
      break;
    case 5:
      drawX(30, 25);
      break;
    case 6:
      drawX(30, 15);
      break;
    case 7:
      drawX(50, 40);
      break;
    case 8:
      drawX(50, 25);
      break;
    case 9:
      drawX(50, 10);
      break;
    case 11:
      drawZero(15, 40);
      break;
    case 12:
      drawZero(15, 25);
      break;
    case 13:
      drawZero(15, 10);
      break;
    case 14:
      drawZero(30, 40);
      break;
    case 15:
      drawZero(30, 25);
      break;
    case 16:
      drawZero(30, 10);
      break;
    case 17:
      drawZero(50, 40);
      break;
    case 18:
      drawZero(50, 25);
      break;
    case 19:
      drawZero(50, 10);
      break;
    case 99:
      drawTo(5, 0);
      break;
  //Get out of the way
  lift(LIFT2);
  drawTo(10, 10);
  detachServos();
void erase() {
  goHome();
  attachServos();
  lift(LIFT0);  // Go down, just before doing the erase movements.
  drawTo(70, ERASER_Y);
  drawTo(5, ERASER_Y);
  drawTo(70, 34);
  drawTo(0, 34);
  drawTo(70, 34);
  drawTo(0, 26);
  drawTo(70, 20);
  drawTo(0, 20);
  drawTo(70, 5);
  drawTo(10, 15);
  drawTo(40, 30);
  drawTo(ERASER_X, ERASER_Y);
  lift(LIFT2 - 100);
  detachServos();
void drawX(float bx, float by) {
  bx = bx - 1;
  by = by + 1;
  //Go
  drawTo(bx, by+1);
  //Draw
  lift(LIFT0);
  drawTo(bx + 10, by + 10);
  //Go
  lift(LIFT2);
  drawTo(bx + 10, by);
  //Draw
  lift(LIFT0);
  drawTo(bx, by + 10);
  lift(LIFT1);
void drawZero(float bx, float by) {
  drawTo(bx + 6, by + 3);
  lift(LIFT0);
  bogenGZS(bx + 3.5, by + 5, 5, -0.8, 6.7, 0.5);
  lift(LIFT1);
void lift(int lift) {
  if (servoLift >= lift) {
    while (servoLift >= lift) {
      servoLift--;
      servo_lift.writeMicroseconds(servoLift);
      delayMicroseconds(LIFT_SPEED);
  else {
    while (servoLift <= lift) {
      servoLift++;
void bogenUZS(float bx, float by, float radius, int start, int ende, float sqee) {
  float inkr = -0.05;
  float count = 0;
  do {
    drawTo(sqee * radius * cos(start + count) + bx,
           radius * sin(start + count) + by);
    count += inkr;
  while ((start + count) > ende);
void bogenGZS(float bx, float by, float radius, int start, int ende, float sqee) {
  float inkr = 0.05;
  float count = 0;
  do {
    count += inkr;
  while ((start + count) <= ende);
void drawTo(double pX, double pY) {
  double dx, dy, c;
  int i;
  // dx dy of new point
  dx = pX - lastX;
  dy = pY - lastY;
  //path lenght in mm, times 4 equals 4 steps per mm
  c = floor(7 * sqrt(dx * dx + dy * dy));
  if (c < 1) c = 1;
  for (i = 0; i <= c; i++) {
    // draw line point by point
    set_XY(lastX + (i * dx / c), lastY + (i * dy / c));
  lastX = pX;
  lastY = pY;
double return_angle(double a, double b, double c) {
  // cosine rule for angle between c and a
  return acos((a * a + c * c - b * b) / (2 * a * c));
void set_XY(double Tx, double Ty) {
  delay(1);
  double dx, dy, c, a1, a2, Hx, Hy;
  // calculate triangle between pen, servoLeft and arm joint
  // cartesian dx/dy
  dx = Tx - O1X;
  dy = Ty - O1Y;
  // polar lemgth (c) and angle (a1)
  c = sqrt(dx * dx + dy * dy); //
  a1 = atan2(dy, dx); //
  a2 = return_angle(L1, L2, c);
  //Serial.print("servo_left:");
  //Serial.println(empty_places);
  servo_left.writeMicroseconds(floor(((a2 + a1 - M_PI) * SERVO_LEFT_FACTOR) + SERVO_LEFT_NULL));
  // calculate joinr arm point for triangle of the right servo arm
  a2 = return_angle(L2, L1, c);
  Hx = Tx + L3 * cos((a1 - a2 + 0.621) + M_PI); //36,5°
  Hy = Ty + L3 * sin((a1 - a2 + 0.621) + M_PI);
  // calculate triangle between pen joint, servoRight and arm joint
  dx = Hx - O2X;
  dy = Hy - O2Y;
  a1 = atan2(dy, dx);
  a2 = return_angle(L1, L4, c);
  //Serial.print("servo_right:");
  //Serial.println(floor(((a1 - a2) * SERVO_RIGHT_FACTOR) + SERVO_RIGHT_NULL));
  servo_right.writeMicroseconds(floor(((a1 - a2) * SERVO_RIGHT_FACTOR) + SERVO_RIGHT_NULL));
void drawFrame() {
  attachServos();
  lift(LIFT2);
  //===VERTICAL
  //Go
  drawTo(30, 10);
  delay(500);
  //Draw
  lift(LIFT0);
  drawTo(25, 50);
  lift(LIFT2);
  //Go
  drawTo(47, 10);
  delay(500);
  //Draw
  lift(LIFT0);
  drawTo(45, 50);
  lift(LIFT2);
  //===HORIZONTAL
  //Go
  drawTo(10, 23);
  //Draw
  lift(LIFT0);
  drawTo(60, 23);
  lift(LIFT2);
  //Go
  drawTo(10, 35);
  //Draw
  lift(LIFT0);
  drawTo(60, 35);
  lift(LIFT2);
  detachServos();
void goHome() {
  //initial servo location
  servo_lift.writeMicroseconds(800);
  servo_left.writeMicroseconds(1633);
  servo_right.writeMicroseconds(2289);
  servo_lift.attach(LIFT_SERO_PIN);
  servo_left.attach(LEFT_SERVO_PIN);
  servo_right.attach(RIGHT_SERVO_PIN);
  lift(LIFT2 - 100); // Lift all the way up.
  lift(LIFT0);
  delay(500);
  //lift(LIFT2);
  detachServos();
void detachServos() {
  servo_lift.detach();
  servo_left.detach();
  servo_right.detach();
void attachServos() {
Mirko Pavleski
