Hue @ Lolin D32 Pro (ESP32) |
Basic demo of switch based on touch TFT display to demonstrate |
communication between ESP and Hue gateway |
Version: 1.00 |
by Petr Lukas |
Functionality: |
Touch a button on TFT to switch on and off the lights. |
#include <WiFi.h> |
#include <HTTPClient.h> |
#include <Adafruit_GFX.h> |
#include <Adafruit_ImageReader.h> |
#include <Adafruit_ILI9341.h> |
#include <SPI.h> |
#include <SD.h> |
// Touchscreen library |
#include <XPT2046_Touchscreen.h> |
// Fonts |
#include <Fonts/FreeMono9pt7b.h> |
#include <Fonts/FreeSansBold9pt7b.h> |
#include <Fonts/FreeSansBold12pt7b.h> |
// Default pin numbers for D32 Pro |
#define TFT_CS 14 |
#define TFT_DC 27 |
#define TFT_RST 33 |
#define TS_CS 12 |
// SD card pin |
#define SD_CS 4 |
// IP of Hue gateway |
String ip = "YOUR_HUE_BRIDGE_IP"; |
// Hue gateway user name |
String user_name = "YOUR_HUE_AUTHORIZED_USER"; |
// Wifi network SSID |
const char* ssid = "YOUR_SSID"; |
// Wifi network password |
const char* password = "YOUR_PASSWORD"; |
// Power consumtion per bulb |
float consumption = 8.5; // Let's assume consumption of bulb in full light is 8.5 W |
unsigned long previousMillis = 0; |
bool state1 = false; |
bool state2 = false; |
bool state3 = false; |
float total_consumption = 0; |
int runtime = 0; |
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_RST); |
Adafruit_ImageReader reader; |
XPT2046_Touchscreen ts(TS_CS); |
void setup() { |
// put your setup code here, to run once: |
Serial.begin(115200); |
tft.begin(); |
tft.setFont(&FreeMono9pt7b); |
tft.fillScreen(ILI9341_BLACK); |
tft.setCursor(0, 15); |
tft.println("Init SD card..."); |
if (!SD.begin(SD_CS)) { |
tft.setTextColor(ILI9341_RED); |
Serial.println("SD card failed"); |
tft.println("Failed!"); |
delay(999999); |
return; |
WiFi.begin(ssid, password); |
tft.println("Connecting to WiFi"); |
Serial.print("Connecting to WiFi"); |
while (WiFi.status() != WL_CONNECTED) { |
delay(1000); |
Serial.print("."); |
Serial.println("Connected to the WiFi network"); |
tft.println("Success"); |
delay(500); |
tft.println("Init touchscreen..."); |
ts.begin(); |
tft.println("Setup complete"); |
tft.println("Starting loop..."); |
delay(500); |
drawButtons(); |
void switchLight(byte light_id, bool current_state, int x, int y){ |
HTTPClient http; |
String req_string; |
req_string = "http://"; |
req_string += ip; |
req_string += "/api/"; |
req_string += user_name; |
req_string += "/lights/"; |
req_string += light_id; |
req_string += "/state"; |
Serial.println(req_string); |
http.begin(req_string); |
http.addHeader("Content-Type", "text/plain"); |
String put_string; |
put_string = "{\"on\":"; |
put_string += (current_state)? "true" : "false"; |
put_string += "}"; |
int httpResponseCode = http.PUT(put_string); |
// Change button only in case the operation is successfull |
if(httpResponseCode == 200){ |
toggleButton(x,y,current_state); |
if(httpResponseCode > 0){ |
String response = http.getString(); |
Serial.println(httpResponseCode); |
Serial.println(response); |
} else { |
Serial.print("Error on sending PUT Request: "); |
http.end(); |
void drawButtons(){ |
int y = 115; |
int y_space = 60; |
reader.drawBMP("/wemos.bmp", tft, 10, 20); |
reader.drawBMP("/hue.bmp", tft, 180, 20); |
reader.drawBMP("/off.bmp", tft, 130, y); |
reader.drawBMP("/off.bmp", tft, 130, y + y_space); |
reader.drawBMP("/off.bmp", tft, 130, y + y_space*2); |
tft.setFont(&FreeSansBold12pt7b); |
y = y + 22; |
tft.setCursor(3, y); |
tft.println("Hall:"); |
tft.setCursor(3, y + y_space); |
tft.println("Bedroom:"); |
tft.setCursor(3, y + y_space*2); |
tft.println("Bathroom:"); |
tft.setFont(&FreeSansBold9pt7b); |
tft.setCursor(50, 310); |
tft.println("0.00 Wh | 0 min"); |
void toggleButton(int x, int y, bool state){ |
if(state){ |
reader.drawBMP("/on.bmp", tft, x, y); |
} else { |
reader.drawBMP("/off.bmp", tft, x, y); |
void loop() { |
unsigned long currentMillis = millis(); |
if (currentMillis - previousMillis >= 1000){ |
if(state1)total_consumption += consumption/3600; |
if(state2)total_consumption += consumption/3600; |
if(state3)total_consumption += consumption/3600; |
runtime++; |
tft.fillRect(0,285,240,320,ILI9341_BLACK); |
tft.print(total_consumption,2); |
tft.print(" Wh | "); |
tft.print(runtime/60); |
tft.print(" min"); |
previousMillis = currentMillis; |
if (ts.touched()) { |
TS_Point p = ts.getPoint(); |
// You need to test coordinates (in this case landscape oriented) |
tft.setCursor(0,50); |
tft.fillRect(0,30,100,50,ILI9341_BLACK); |
tft.println(p.x); |
tft.println(p.y); |
if((p.x < 2500 && p.x > 2000) && (p.y < 1800 && p.y > 300)){ |
state1 = !state1; |
switchLight(1, state1, 130, 115); |
if((p.x < 2000 && p.x > 1500) && (p.y < 1800 && p.y > 300)){ |
state2 = !state2; |
switchLight(2, state2, 130, 175); |
if((p.x < 1500 && p.x > 1000) && (p.y < 1800 && p.y > 300)){ |
state3 = !state3; |
switchLight(3, state3, 130, 235); |
delay(500); |
