Create a Smart Blind Stick Using Arduino Plus 3 Sonars
SU
February 09, 2018 by SM UmerLatif
The 3 sonars are getting 3 different distances of theobstacles in the way of the blind person and then give the beep
blind stick
Blind stick is used by blind to avoid obstacles and walk around. It’s an ancient way for blind persons to make them walk easily. But this is now old technique. We are creating a new way for blind people so that they could walk around with max efficiency and good accuracy. This device consists of 3 sonars aligned in a semi-hexagonal structure which would increase the accuracy of obstacle avoiding. One is located at the main front and two are attached sideways with the main one making an angle of 45degree with the main one. Also there will be 3 buzzers connected with each one of the sonars. So if there comes any obstacles in any of the 3 dimensions the specified buzzer will beep the obstacle approaching. Also there is a speaking part involve in which we use an amplifier, a speaker and sd-card module for the wav file.
Materials Required:
• Arduino Uno
• 3 x Ultrasonic Sensor HC-SR04
• 3 x Buzzer
• Speaker
• On/off button
• 9V battery
• Pcb board
• Sd-card module
• Micro Sd-card
• Wav formatter
• Jumper wires
• Soldering kit & glue gun (for fabrication)
• A card board Box
  • ULTRASONIC RANGE FINDER ON AN ARDUINO
Ultrasonic range finders are fun little modules that measure distance. You can use them to find the distance to an object, or to detect when something is near the sensor like a motion detector. They’re ideal for projects involving navigation, object avoidance, and home security. Because they use sound to measure distance, they work just as well in the dark as they do in the light. The ultrasonic range finder I’ll be using in this tutorial is the HC-SR04, which can measure distances from 2 cm up to 4oo cm with an accuracy of ±3 mm.
3 sonars plus 3 buzzer each having one pcb.
single pcb
#define trigPin 13
#define echoPin 12
#define buzzer 6
#define buzzer1 5
#define buzzer2 4
#define trigPin1 11
#define echoPin1 10
#define trigPin2 9
#define echoPin2 8
#define dataPin A0
void setup()
{ pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(trigPin1, OUTPUT);
pinMode(echoPin1, INPUT);
pinMode(trigPin2, OUTPUT);
pinMode(echoPin2, INPUT);
pinMode(buzzer,OUTPUT);
pinMode(buzzer1,OUTPUT);
pinMode(buzzer2,OUTPUT);
void loop()
{ long dur, dist, dur1, dur2, dist1, dist2;
digitalWrite(trigPin, LOW);
delayMicroseconds(4);
digitalWrite(trigPin, HIGH);
dur = pulseIn(echoPin, HIGH);
dist = (dur/2) / 29.1;
if (dist < 73 && dist>35) // Checking the distance, you can change the value
 digitalWrite(buzzer,HIGH);
  for (int i=dist; i>0; i--)
    delay(9);
  digitalWrite(buzzer,LOW);
    delay(9);
} delay(100);
if (dist <= 35 && dist>8) // Checking the distance, you can change the value
    delay(5);
    delay(2);
} delay(30);
if(dist<=8)
{digitalWrite(buzzer,HIGH);
}else
// when greater than 50cm
} delay(500);
//2nd sonar code*********
digitalWrite(trigPin1, LOW);
delayMicroseconds(2);
digitalWrite(trigPin1, HIGH);
delayMicroseconds(5);
dur1 = pulseIn(echoPin1, HIGH);
dist1 = (dur1/2) / 29.1;
if (dist1 < 20) // Checking the distance, you can change the value
 digitalWrite(buzzer1,HIGH);
else
  digitalWrite(buzzer1,LOW);
 delay(500);
//3rd sonar code*********
digitalWrite(trigPin2, LOW);
digitalWrite(trigPin2, HIGH);
dur2 = pulseIn(echoPin2, HIGH);
dist2 = (dur2/2) / 29.1;
if (dist2 < 20) // Checking the distance, you can change the value
 digitalWrite(buzzer2,HIGH);
else
  digitalWrite(buzzer2,LOW);
 delay(500);
SU
SM UmerLatif
Electrical telecom engineer Mcs,Nust.love to mess with circuits. made many projects and want to make project making easy
