Servo motor and Arduino UNO on Virtual Arduino online Simulator
March 14, 2021 by share Open-Tech
This project demonstrates the code for servo motor sweep example on virtual Arduino simulator from wokwi.
Servo motor basics
Servo motors are very much user-friendly compared to other motors. The programming is easy. The software drivers are easily available.
The Servo motors consist of a small intelligent comparator inside which can be programmed using a PWM signal. The angle of rotation is controlled by the pulse width oh the PWM signal. What this means is, even if there is a slight offset in the rotation angle (due to the load or due to a small shock) it will be corrected sooner. This Servo motor feature makes it a good candidate for several applications such as robotic arms, dispensers and more.
The Servo motor element is present in the wokwi Arduino simulator. Click here to see the element properties
Wokwi Virtual Arduino Simulator simulating Servo motor
Servo motor element in Virtual Arduino Simulator
Project 1: Knob code example for Servo motor on Virtual Arduino Simulator
Wokwi Arduino Simulator - Knob example for Servo motor
Servo motor Arduino project - knob example
 Controlling a servo position using a potentiometer (variable resistor)
 by Michal Rinott <http://people.interaction-ivrea.it/m.rinott>
 modified on 8 Nov 2013
 by Scott Fitzgerald
 http://www.arduino.cc/en/Tutorial/Knob
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
int potpin = 0;  // analog pin used to connect the potentiometer
int val;    // variable to read the value from the analog pin
void setup() {
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
void loop() {
  val = analogRead(potpin);            // reads the value of the potentiometer (value between 0 and 1023)
  val = map(val, 0, 1023, 0, 180);     // scale it to use it with the servo (value between 0 and 180)
  myservo.write(val);                  // sets the servo position according to the scaled value
  delay(15);                           // waits for the servo to get there
You can play with the project here on the Wokwi Arduino simulator: https://wokwi.com/arduino/libraries/Servo/Knob
Project 2: Sweep example for Servo motor
wokwi Arduino simulator - Sweep example
Wokwi Arduino Simulator example = Servo motor 180-degree sweep
/* Sweep
 by BARRAGAN <http://barraganstudio.com>
 This example code is in the public domain.
 modified 8 Nov 2013
 by Scott Fitzgerald
 http://www.arduino.cc/en/Tutorial/Sweep
#include <Servo.h>
// twelve servo objects can be created on most boards
int pos = 0;    // variable to store the servo position
void setup() {
void loop() {
  for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
    // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
You can tinker with the code for the project above here
More about virtual Arduino online simulator from Wokwi
share Open-Tech
Hardware enthusiast with ample interest in Arduino projects
