Nixie Clock Thermometer Hygrometer - Shield for Arduino
April 07, 2019 by Marcin Saj
Use your Arduino and build Nixie clock, thermometer and hygrometer. Beautifully made housing and easy to operate.
Project can be found on crowdfunding campaign: https://www.NixieTester.com
Parameters & Components
  • Perfect quality housing (color: black, red, blue), laser-cut and engraved
  • Housing dimensions: 60 x 80 x 158 mm (~2.4" x 3.1" x 6.2")
  • High quality connectors & pin headers (only these components require soldering)
  • Nixie power supply module 170V
  • Extremely accurate RTC module - DS3231
  • Precise and accurate temperature & humidity sensor DHT22
  • Shield requires +12V power supply (Arduino Vin power supply connector)
  • Compatible with Arduino UNO.
How does this work?
What's Inside
Replaceable Nixie Tubes
Three device options are possible:
  • Nixie Clock - 4 x IN-12B Nixie Tubes
  • Fahrenheit - Nixie Thermometer/Hygrometer - 3 x IN-12B + IN-15B Nixie Tubes
  • Cesius - Nixie Thermometer/Hygrometer - 3 x IN-12B + IN-15A Nixie Tubes.
Easy Arduino Coding
Datasheet and examples codes can be found in the project repository. Code is very simple and uses only two Arduino libraries: for real time clock DS3231 and second for temperature and humidity sensor DHT22. Nixie tubes are controlled by HV5812 high voltage drivers by using only 3 arduino pins. You can modify the code according to your own ideas.
- GitHub Repository
Schematic
Nixie Clock Thermometer Hygrometer Arduino Shield - Schematic
Project Update - New Housing
Transparent Housing
Nixie Clock Thermometer Hygrometer Arduino Shield - Transparent Housing
