This project shows how you can make our own ultra bass powerful amplifier in your home!
ULTRA Bass Amplifier is nothing but a high power amplifier with high gain and capable of Amplifying Small signals (mainly sounds )
What is ULTRA Bass Powerful Amplifier?
An amplifier circuit represents a circuit which just multiplies the input signal by a constant/variable amount (Depending upon various circuit conditions) and provides an output signal which we call the amplified signal, so the ULTRA Bass Amplifier is nothing but a high power amplifier with high gain and capable of Amplifying Small signals (mainly sounds ) and it adds the Bass Property to the sound waves which reduce the noise level also.
Materials
Materials from UTSource.net
D718 Transistor (2 nos)
10 Ohm 20 Watt
C2383 Transistor
100k Resistor
2.2 Ohm Resistor
104 P.F. Capacitor (4 nos)
25V 220 UF Capacitor
25V 2220 UF Capacitor
50K Volume
1.5K Resistor (2 nos)
Step By Step Procedure
Step 1: First the 2 DN718 Transistor has to be fixed in an insulating console (bed) via screws.
Step 2: Then Take a piece of cardboard (Rectangular shape and the area must be three times bigger than the bed ) and fix the bed in a corner of this cardboard via high-adhesive glues.
Step 3: Connect Emitter of the First Transistor to the second and repeat this step for the Base and the Collector.
Step 4: Connect the 10 Ohm side to the Collector of any of the Transistors and keep open the 20 Watt side for now as shown in the below figure.
Step 5: Connect the C283 Emitter Connection to the Base of Combined
Step 6: Now Connect the 100k Resistor to the Base and Collector of the C2383 as shown in the below figure.
Step 7: Now the 2200Uf +ve has to connected to the Collector Terminal of D718.
Step 8: Now 2200 Ohm Resistor has to connected to the Collector Terminal of D718.
Step 9: The 104 Pf in emitter has to be connected to the Emitter and 2.2 Ohm Resistor as shown in the figure.
Making the Bass Treble Circuit.
Step 1: Now place the volume controllers via glue in sidewise arrangement as shown in the figure.
Step 2: Connect the 104 Pf Capacitors to the Volume Control with wires as shown in the below figure .
Step 3: Now make the entire connection of the control panel as per the given below proper circuit diagram
Now, this control panel circuit of the Amplifier is complete.
Now Connect the Subwoofer as per the shown below figure and test the entire system.
Conclusion
So from the construction of this circuit, we come to this end and have seen that by minimum expenditure we can make our own Ultra Bass Powerful Amplifier in our home, so keep making and adding stuff and electronics world and enjoy music for now.
