Build a Hand Gesture Controlled Toy Car
RB
June 01, 2018 by Ritbik Bharti
A hand gesture-controlled toy which can move forward, backward, left and right and also detects obstacles.
The transmitter circuit
The Receiver
This is the car on which receiver circuit is embedded which receives the signal from the transmitter and accordingly the car moves.
The receiver circuit
//Connect the Receiver data pin to Arduino pin 11
#include <VirtualWire.h>
byte message[VW_MAX_MESSAGE_LEN]; // a buffer to store the incoming messages
byte messageLength = VW_MAX_MESSAGE_LEN; // the size of the message
#define ep 4
#define tp 3
int en1=9;
int en2=10;
int in1=5;
int in2=6;
int in3=7;
int in4=8;
int buzzerPin=2;
int ledPin=13;//led on pin 13 is ON except when bot is stationary
long duration, distance;
void setup()
 Serial.begin(9600);//Initialise theserial connection debugging
 pinMode(tp,OUTPUT);
 pinMode(ep,INPUT);
 pinMode(ledPin,OUTPUT);
 pinMode(buzzerPin,OUTPUT);
 pinMode(en1,OUTPUT);
 pinMode(en2,OUTPUT);
 pinMode(in1,OUTPUT);
 pinMode(in2,OUTPUT);
 pinMode(in3,OUTPUT);
 pinMode(in4,OUTPUT);
 vw_setup(2000); // Bits per sec
 vw_rx_start(); // Start the receiver
void loop()
  digitalWrite(tp,LOW);
  delayMicroseconds(2);
  digitalWrite(tp,HIGH);
  delayMicroseconds(10);
  duration=pulseIn(ep,HIGH);
  distance=duration/58.2;
  Serial.println(distance);
  if (distance < 10 )
    Serial.print("Obstacle detected\n");
    digitalWrite(buzzerPin,HIGH);
  else
    Serial.print("Obstacle not detected\n");
    digitalWrite(buzzerPin,LOW);
    uint8_t buf[VW_MAX_MESSAGE_LEN];
    uint8_t buflen = VW_MAX_MESSAGE_LEN;
    if (vw_get_message(buf, &buflen)) // Non-blocking
  int i;
  Serial.print("Got: ");//debugging
  for (i = 0; i < buflen; i++)
     Serial.print(buf[i],HEX);//You may also use integer values debugging
     Serial.print(' ');// debugging
          if (buf[i]==0x6F)//Stationary
            digitalWrite(en1,LOW);
            digitalWrite(in1,LOW);
            digitalWrite(in2,LOW);
            digitalWrite(en2,LOW);
            digitalWrite(in3,LOW);
            digitalWrite(in4,LOW);
          Serial.print("Stationary");
            digitalWrite(ledPin,LOW);
          else
            if(buf[i]==0x68)//Forward
              digitalWrite(en1,HIGH);
              digitalWrite(in2,HIGH);
              digitalWrite(en2,HIGH);
              digitalWrite(in3,HIGH);
            Serial.print("Forward");
              digitalWrite(ledPin,HIGH);
            if (buf[i]==0x69)//Backward
              digitalWrite(in1,HIGH);
              digitalWrite(in4,HIGH);
            Serial.print("Backward");
            if (buf[i]==0x62)//Right
              Serial.print("Right");
            if (buf[i]==0x65)//Left
              Serial.print("Left");
    Serial.print("\n");// debugging
        delay(100);
