EPOXY RESIN LED CLOCK
January 11, 2019 by Taner Özdil
Hi Maker, We are proud to present our new project. “EPOXY RESIN LED CLOCK”.
Before you start, What is epoxy? Epoxy resin is known for its strong adhesive qualities, making it a versatile product in many industries. It offers resistance to heat and chemical applications, making it an ideal product for anyone needing a strong hold under pressure. Epoxy resin is also a durable product which can be used with various materials, including: wood, fabric, glass, china or metal.
This project was a first. There's no other place. And now we have presented it to you. We had some epoxy. We thought what we could use it for. We did a little research and found that there wasn't an epoxy clock. We have designed. We print. We combined it with RGB. and we have brought this unique project to you.
This project also used the addressable WS2812B led. In order to show you that we used 60 LED in 1 meter for hours and 144 LED in 2 meters for minutes and seconds. Of course, arduino nano is our everything. It is a brain.
This project is divided into 3 parts. Parts;
1- Materials and Electronic Design
2- Making Epoxy
3- Assemble and Showtime
And no more words. Ladies and Gentlemen Please Welcome “EPOXY RESIN LED CLOCK”
#include <DS3231.h>
#include <Adafruit_NeoPixel.h>
#ifdef __AVR__
  #include <avr/power.h>
#endif
#define PIN            5
#define PIN2           7
#define NUMPIXELS      60
DS3231  rtc(SDA, SCL);
Time  t;
int hr;
int mnt;
int sc;
char data;
char color_select;
int h_red_deger=255;
int h_green_deger=0;
int h_blue_deger=0;
int m_red_deger=0;
int m_green_deger=255;
int m_blue_deger=0;
int s_red_deger=255;
int s_green_deger=255;
int s_blue_deger=0;
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel pixels2 = Adafruit_NeoPixel(12, PIN2, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel strip2 = Adafruit_NeoPixel(12, PIN2, NEO_GRB + NEO_KHZ800);
int delayval = 10;
void setup() {
  Serial.begin(9600);
   rtc.begin();
#if defined (__AVR_ATtiny85__)
  if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
#endif
  // End of trinket special code
  pixels.begin(); // This initializes the NeoPixel library.
  pixels2.begin();
  strip.begin();
  strip.show();
  strip2.begin();
  strip2.show();
void loop() {
  while(Serial.available() > 0) // bağlantı kuruluyken
  delay(10);
  char c = Serial.read();
  data=c;
    if(data=='m')
      data=' ';
      t = rtc.getTime();
      hr=t.hour;
      mnt=t.min;
      sc=t.sec;
      while(data!='m')
        data=Serial.read();
        if(data=='+')
           hr++;
        if(data=='-')
           hr--;
         for(int i=0;i<12;i++){pixels2.setPixelColor(i, pixels2.Color(0,255,10));}
         pixels2.show();
         if(hr>=12){hr=hr-12;}
         if(hr<0){hr=hr+12;}
         pixels2.setPixelColor(hr, pixels2.Color(255,0,0));
         pixels2.show();
         delay(100);
         pixels2.setPixelColor(hr, pixels2.Color(0,0,0));
         pixels2.show();
         delay(100);
      rtc.setTime(hr,mnt,sc);
      if(data=='m')
         data=' ';
         t = rtc.getTime();
         hr=t.hour;
         mnt=t.min;
         sc=t.sec;
         while(data!='m')
             data=Serial.read();
             if(data=='+')
              mnt++;
              if(mnt==60)
              {mnt=0;}
             if(data=='-')
              if(mnt==0)
              {mnt=60;}
              mnt--;
              for(int k=0;k<60;k++){pixels.setPixelColor(k, pixels.Color(0,0,0));}
              for(int k=0;k<60;k++){pixels.setPixelColor(k, pixels.Color(25,25,255));k=k+4;}
               pixels.setPixelColor(mnt, pixels.Color(0,250,0));
               pixels.show();
               delay(100);
               pixels.setPixelColor(mnt, pixels.Color(0,0,0));
               pixels.show();
               delay(100);
           data=' ';
        if(data=='H')
       color_select=data;
     if(data=='M')
       color_select=data;
     if(data=='S')
       color_select=data;
     if(data=='A')
      data=' ';
      colorWipe(strip.Color(255, 0, 0), 50); // Red
  colorWipe(strip.Color(0, 255, 0), 50); // Green
  colorWipe(strip.Color(0, 0, 255), 50); // Blue
//colorWipe(strip.Color(0, 0, 0, 255), 50); // White RGBW
  // Send a theater pixel chase in...
  theaterChase(strip.Color(127, 127, 127), 50); // White
  theaterChase(strip.Color(127, 0, 0), 50); // Red
  theaterChase(strip.Color(0, 0, 127), 50); // Blue
  rainbow(20);
  rainbowCycle(20);
  theaterChaseRainbow(50);
      if(data=='r'&&color_select=='H')
          h_red_deger=Serial.parseInt();
          pixels2.setPixelColor(hr, pixels2.Color(h_red_deger,h_green_deger, h_blue_deger));
          pixels2.show();
         if(data=='g'&&color_select=='H')
      { h_green_deger=Serial.parseInt();
          pixels2.show();
        if(data=='b'&&color_select=='H')
         h_blue_deger=Serial.parseInt();
          pixels2.show();
 if(data=='r'&&color_select=='M')
          m_red_deger=Serial.parseInt();
          pixels.setPixelColor(mnt, pixels.Color(m_red_deger,m_green_deger,m_blue_deger));
  pixels.show();
         if(data=='g'&&color_select=='M')
      { m_green_deger=Serial.parseInt();
         pixels.show();
        if(data=='b'&&color_select=='M')
         m_blue_deger=Serial.parseInt();
         pixels.show();
if(data=='r'&&color_select=='S')
          s_red_deger=Serial.parseInt();
          pixels.setPixelColor(sc, pixels.Color(s_red_deger,s_green_deger,s_blue_deger));
  pixels.show();
         if(data=='g'&&color_select=='S')
      { s_green_deger=Serial.parseInt();
         pixels.show();
        if(data=='b'&&color_select=='S')
         s_blue_deger=Serial.parseInt();
         pixels.show();
           t = rtc.getTime();
           hr=t.hour;
           mnt=t.min;
           sc=t.sec;
  pixels.show();
    if(i==hr)
    {i++;}
    pixels2.setPixelColor(i, pixels2.Color(0,0,0));}
  pixels2.show();
  pixels2.setPixelColor(hr, pixels2.Color(h_red_deger,h_green_deger,h_blue_deger));
  pixels2.show();
  delay(10);
  pixels.setPixelColor(sc, pixels.Color(0,0,0));
  for(int k=0;k<60;k++){pixels.setPixelColor(k, pixels.Color(10,10,10));k=k+4;}
  pixels.show();
void colorWipe(uint32_t c, uint8_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
    strip.setPixelColor(i, c);
    strip.show();
    strip2.setPixelColor(i, c);
    strip2.show();
    delay(wait);
void rainbow(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256; j++) {
    for(i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel((i+j) & 255));
      strip2.setPixelColor(i, Wheel((i+j) & 255));
    strip2.show();
    strip.show();
    delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
      strip2.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
    strip2.show();
    delay(wait);
//Theatre-style crawling lights.
void theaterChase(uint32_t c, uint8_t wait) {
  for (int j=0; j<10; j++) {  //do 10 cycles of chasing
    for (int q=0; q < 3; q++) {
      for (int i=0; i < strip.numPixels(); i=i+3) {
        strip.setPixelColor(i+q, c);    //turn every third pixel on
        strip2.setPixelColor(i+q, c);
      strip2.show();
      strip.show();
      delay(wait);
        strip.setPixelColor(i+q, 0);        //turn every third pixel off
        strip2.setPixelColor(i+q, 0);
//Theatre-style crawling lights with rainbow effect
void theaterChaseRainbow(uint8_t wait) {
  for (int j=0; j < 256; j++) {     // cycle all 256 colors in the wheel
        strip.setPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel on
        strip2.setPixelColor(i+q, Wheel( (i+j) % 255));
      strip2.show();
      strip.show();
      delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  if(WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
Taner Özdil
Hi, This is Taner from Turkey. I am tecnical teacher at a hşgh school. And I am a maker about all electronics
