How to Test Logic IC Gates with Arduino
September 04, 2018 by rodrigo mejias
Test AND, OR, NOT and other logic IC gates with Arduino MEGA and it's 5" touch screen to select and view Truth Table.
Enjoy testing IC logic gates through this Touch System
Schematic
Remember after this wiring to assembling Arduino MEGA with TFT Shield and finally install 5" TFT screen
#include <SPI.h>            // Librería para usar tarjeta SD
#include <SdFat.h>          // Complemento para Usar tarjeta SD
#include <UTFT_SdRaw.h>     // Complement para usar tarjeta SD
#define SD_CHIP_SELECT  53  // SD chip select pin
#include <UTFT.h>  // Librería para habilitar pantalla TFT
#include <UTouch.h>
UTouch  myTouch( 6, 5, 4, 3, 8);
SdFat sd;
UTFT myGLCD(CTE50,38,39,40,41);   // Definición de pines para habilitar pantalla LCD
UTFT_SdRaw myFiles(&myGLCD);      // Comando para acelerar la carga de imágenes
const int LUZlcd = 44;
int brightness   = 0;
int x,y;
extern uint8_t OCR_A_Extended_M[];
int draw =0;
int test =0;
int logic=0;
int gate=0;
int ejercicio=0;
int ANDstate   =0;
int ORstate    =0;
int NOTstate   =0;
int BUFFERstate=0;
int NANDstate  =0;
int NORstate   =0;
int XNORstate  =0;
int XORstate   =0;
const int out1 = 8; // patilla #1 en IC
const int out2 = 9; // patilla #2 en IC
const int out3 = 10;// patilla #3 en IC
const int out4 = 11;// patilla #4 en IC
const int out5 = 12;// patilla #5 en IC
const int out6 = A0;// patilla #6 en IC
const int out7 = A1;// patilla #8 en IC
const int out8 = A2;// patilla #9 en IC
const int out9 = A3;// patilla #10 en IC
const int out10= A4;// patilla #11 en IC
const int out11= A5;// patilla #12 en IC
const int out12= A6;// patilla #13 en IC
int read1;
int read2;
int read3;
int read4;
int read5;
int read6;
void setup() {
    myGLCD.InitLCD();
    pinMode(LUZlcd, OUTPUT);
    myTouch.InitTouch();
    myTouch.setPrecision(PREC_HI);
    Serial.println(F("Initialising SD card..."));
  bool mysd = 0;  // see if the card is present and can be initialized:
  while (!mysd)
    if (!sd.begin(SD_CHIP_SELECT, SPI_FULL_SPEED)) {
     Serial.println(F("Card failed, or not present"));
     Serial.println(F("Retrying...."));
    else
      mysd = 1;
     Serial.println(F("Card initialised."));
    Serial.begin(9600);
    while (!Serial); // wait for Leonardo enumeration, others continue immediately
PP();
  myGLCD.setFont(OCR_A_Extended_M);
  myGLCD.setBackColor(32,32,228);
  myGLCD.setColor(VGA_BLACK);
  myGLCD.fillRect(137,17,152,32);
  myGLCD.fillRect(247,17,262,32);
  myGLCD.fillRect(356,17,371,32);
  myGLCD.fillRect(465,17,480,32);
  myGLCD.fillRect(138,104,153,119);
  myGLCD.fillRect(247,104,262,119);
  myGLCD.fillRect(356,104,371,119);
  myGLCD.fillRect(465,104,480,119);
  myGLCD.setColor(VGA_YELLOW);
  myGLCD.print("Y",710,55);
  myGLCD.print(" ",590,55);
  myGLCD.print(" ",615,55);
  myGLCD.print(" ",640,55);
void loop() {
  Serial.print ("dentro de LOOP");
  while (myTouch.dataAvailable() == true)
    myTouch.read();
    x = myTouch.getX();
    y = myTouch.getY();
    if ((x!=-1) and (y!=-1))
      Serial.print(x);
      Serial.print(" X ");
      Serial.print(y);
      Serial.println(" Y ");
   //  myGLCD.drawPixel (x, y);
    // Test button
    if ((y>=320) && (y<=430)){
      if ((x>=600) && (x<=710)){
        test = 1;
        // If some logic GATE has been selected then set Circuit to TEST
    if (logic >=1){
      Serial.println("dentro de IF LOGIC");
      myGLCD.fillRect(578,95,670,280);
      myGLCD.fillRect(688,95,747,280);
      ANDstate   =0;
      ORstate    =0;
      NOTstate   =0;
      BUFFERstate=0;
      NANDstate  =0;
      NORstate   =0;
      XNORstate  =0;
      XORstate   =0;
      TEST();
        delay(300);
    circuitos();
    // Primera Pantalla
void PP(){
  myFiles.load(0,0, 800,480, "main.RAW");
  digitalWrite(LUZlcd, HIGH);
void circuitos(){
      // Seleccion AND GATE
   if ((y>=20) && (y<=74)){
      if ((x>=70) && (x<=145)){
      myGLCD.setColor(VGA_LIME);
      myFiles.load(54,255, 426,164, "and.RAW");
      myGLCD.print("A",590,55);
      myGLCD.fillCircle(623,65,4);
      myGLCD.print("B",640,55);
      myGLCD.setColor(32,32,228);
      myGLCD.drawLine(590,48,657,48);
      myGLCD.drawLine(590,49,657,49);
      myGLCD.drawCircle(623,65,10);
      pinMode(out1, OUTPUT);
      pinMode(out2, OUTPUT);
      pinMode(out3,  INPUT);
      pinMode(out4, OUTPUT);
      pinMode(out5, OUTPUT);
      pinMode(out6,  INPUT);
      pinMode(out7,  INPUT);
      pinMode(out8, OUTPUT);
      pinMode(out9, OUTPUT);
      pinMode(out10, INPUT);
      pinMode(out11,OUTPUT);
      pinMode(out12,OUTPUT);
      test  = 1;
      logic = 1;
      ejercicio = 0;
      x=0;
      y=0;
      ANDstate=0;
     // Seleccion OR GATE
      if ((x>=180) && (x<=255)){
      myFiles.load(54,255, 426,164,  "or.RAW");
      myGLCD.print("+",615,55);
      test  = 1;
      logic = 2;
      ejercicio = 0;
      x=0;
      y=0;
      ORstate=0;
     // Seleccion NOT GATE
      if ((x>=290) && (x<=365)){
       myFiles.load(54,255, 426,164, "not.RAW");
       myGLCD.print("A",615,55);
       myGLCD.drawLine(615,48,633,48);
       myGLCD.drawLine(615,49,633,49);
       pinMode(out1,OUTPUT);
      pinMode(out2,  INPUT);
      pinMode(out3, OUTPUT);
      pinMode(out4,  INPUT);
      pinMode(out9,  INPUT);
      pinMode(out10,OUTPUT);
      pinMode(out11, INPUT);
      test  = 1;
      logic = 3;
      ejercicio = 0;
      x=0;
      y=0;
      NOTstate=0;
      // Seleccion BUFFER GATE
      if ((x>=400) && (x<=475)){
       myFiles.load(54,255, 426,164, "buffer.RAW");
      test  = 1;
      logic = 4;
      ejercicio = 0;
      x=0;
      y=0;
  // Seleccion NAND GATE
     if ((y>=100) && (y<=168)){
      myFiles.load(54,255, 426,164, "nand.RAW");
      test  = 1;
      logic = 5;
      ejercicio = 0;
      x=0;
      y=0;
      NANDstate=0;
  // Seleccion NOR GATE
      myFiles.load(54,255, 426,164, "nor.RAW");
      pinMode(out1,  INPUT);
      pinMode(out6, OUTPUT);
      pinMode(out7, OUTPUT);
      pinMode(out12, INPUT);
      test  = 1;
      logic = 6;
      ejercicio = 0;
      x=0;
      y=0;
  // Seleccion XNOR GATE
      myFiles.load(54,255, 426,164, "xnor.RAW");
      test  = 1;
      logic = 7;
      ejercicio = 0;
      x=0;
      y=0;
  // Seleccion XOR GATE
      myFiles.load(54,255, 426,164, "xor.RAW");
      test  = 1;
      logic = 8;
      ejercicio = 0;
      x=0;
      y=0;
void TEST(){
  switch (logic){
    case 1: // Ejecuta test a compuerta AND
            // Entrada 0 y 0 en GATE 1
        myGLCD.setBackColor(VGA_BLACK);
        myGLCD.print("GATE 1",577,260);
        myGLCD.fillRect(53,418,58,364);
        myGLCD.fillRect(59,364,133,368);
        myGLCD.fillRect(117,418,122,383);
        myGLCD.fillRect(123,383,133,387);
        digitalWrite(out1, LOW);
        myGLCD.print("0",590,100);
        digitalWrite(out2, LOW);
        myGLCD.print("0",640,100);
        delay(1000);
        read1 = digitalRead(out3);
        if(read1 ==HIGH){
          myGLCD.setColor(VGA_WHITE);
          myGLCD.print("1",710,100);
          myGLCD.setColor(VGA_RED);
          myGLCD.fillRect(172,372,193,377);
          myGLCD.fillRect(190,372,195,418);
          else{
          ANDstate = ANDstate+1;
          myGLCD.print("0",710,100);
          // Entrada 0 y 1
           delay(1000);
           myGLCD.print("0",590,140);
           digitalWrite(out2, HIGH);
           myGLCD.print("1",640,140);
           delay(1000);
        if(read1 ==HIGH){
          myGLCD.print("1",710,140);
          else{
          ANDstate = ANDstate + 1;
          myGLCD.print("0",710,140);
          // Entrada 1 y 0
           delay(1000);
           digitalWrite(out1, HIGH);
           myGLCD.print("1",590,180);
           myGLCD.print("0",640,180);
           delay(1000);
        if(read1 ==HIGH){
          myGLCD.print("1",710,180);
          else{
          myGLCD.print("0",710,180);
          // Entrada 1 y 1
           delay(1000);
           myGLCD.print("1",590,220);
           myGLCD.print("1",640,220);
           delay(1000);
        if(read1 ==HIGH){
          myGLCD.print("1",710,220);
          else{
          myGLCD.print("0",710,220);
        delay(1000);
               // Entrada 0 y 0 en GATE 2
        myGLCD.fillRect(580,95,660,260);
        myGLCD.fillRect(710,95,740,280);
        delay(500);
        myGLCD.print("GATE 2",577,260);
        myGLCD.fillRect(264,418,269,364);
        myGLCD.fillRect(270,364,352,369);
        myGLCD.fillRect(336,418,341,383);
        myGLCD.fillRect(342,383,355,387);
        digitalWrite(out4, LOW);
        digitalWrite(out5, LOW);
        delay(1000);
        read2 = digitalRead(out6);
        if(read2 ==HIGH){
          myGLCD.fillRect(390,372,408,377);
          myGLCD.fillRect(409,372,414,418);
          else{
          // Entrada 0 y 1
           delay(1000);
           digitalWrite(out5, HIGH);
           delay(1000);
        if(read2 ==HIGH){
          else{
          // Entrada 1 y 0
           delay(1000);
           digitalWrite(out4, HIGH);
           delay(1000);
        if(read2 ==HIGH){
          else{
          // Entrada 1 y 1
           delay(1000);
           delay(1000);
        if(read2 ==HIGH){
          else{
         delay(1000);
          // Entrada 0 y 0 en GATE 3
        delay(500);
        myGLCD.print("GATE 3",577,260);
        myGLCD.fillRect(412,254,417,269);
        myGLCD.fillRect(395,264,413,269);
        myGLCD.fillRect(395,269,399,293);
        myGLCD.fillRect(400,288,414,293);
        myGLCD.fillRect(339,254,344,312);
        myGLCD.fillRect(345,307,414,312);
        digitalWrite(out8, LOW);
        digitalWrite(out9, LOW);
        delay(1000);
        read3 = digitalRead(out7);
        if(read3 ==HIGH){
          myGLCD.fillRect(454,298,475,302);
          myGLCD.fillRect(472,298,477,254);
          else{
          // Entrada 0 y 1
           delay(1000);
           digitalWrite(out9, HIGH);
           delay(1000);
        if(read3 ==HIGH){
          else{
          // Entrada 1 y 0
           delay(1000);
           digitalWrite(out8, HIGH);
           delay(1000);
        if(read3 ==HIGH){
          else{
          // Entrada 1 y 1
           delay(1000);
           delay(1000);
        if(read3 ==HIGH){
          else{
delay(1000);
          // Entrada 0 y 0 en GATE 4
        delay(500);
        myGLCD.print("GATE 4",577,260);
        myGLCD.fillRect(191,254,196,292);
        myGLCD.fillRect(192,289,208,294);
        myGLCD.fillRect(115,254,120,311);
        myGLCD.fillRect(117,307,208,312);
        digitalWrite(out11, LOW);
        digitalWrite(out12, LOW);
        delay(1000);
        read4 = digitalRead(out10);
        if(read4 ==HIGH){
          myGLCD.fillRect(247,298,267,303);
          myGLCD.fillRect(262,254,267,297);
          else{
          // Entrada 0 y 1
           delay(1000);
           digitalWrite(out12, HIGH);
           delay(1000);
        if(read4 ==HIGH){
          else{
          // Entrada 1 y 0
           delay(1000);
           digitalWrite(out11, HIGH);
           delay(1000);
        if(read4 ==HIGH){
          else{
          // Entrada 1 y 1
           delay(1000);
           delay(1000);
        if(read4 ==HIGH){
          else{
          if(ANDstate == 16){
            myGLCD.print("IC -->",577,260);
            myGLCD.print(" OK ",688,260);
          else{
            myGLCD.print("Fail",688,260);
          Serial.print(ANDstate);
    break;
    case 2: // Ejecuta test a compuerta OR
        Serial.print(" en GATE OR ");
        delay(1000);
        read2 = analogRead(out3);
        Serial.print("digital READ   ");
          Serial.print(read1);
          Serial.print("   Analog READ   ");
          Serial.println(read2);
        if(read1 ==HIGH){
          ORstate = ORstate +1;
          myGLCD.fillRect(179,372,193,377);
          else{
          // Entrada 0 y 1
           delay(1000);
           delay(1000);
          Serial.print(read2);
          if(read1 ==HIGH){
          else{
          // Entrada 1 y 0
           delay(1000);
           delay(1000);
        if(read1 ==HIGH){
          else{
          // Entrada 1 y 1
           delay(1000);
           delay(1000);
        if(read1 ==HIGH){
          else{
        delay(1000);
        delay(500);
        delay(1000);
        if(read2 >=HIGH){
          myGLCD.fillRect(400,372,408,377);
          else{
          // Entrada 0 y 1
           delay(1000);
           delay(1000);
        if(read2 >=HIGH){
          else{
          // Entrada 1 y 0
           delay(1000);
           delay(1000);
        if(read2 >=HIGH){
          else{
          // Entrada 1 y 1
           delay(1000);
           delay(1000);
        if(read2 >=HIGH){
          else{
         delay(1000);
        delay(500);
        delay(1000);
        if(read3 >=HIGH){
          myGLCD.fillRect(466,298,475,302);
          else{
          // Entrada 0 y 1
           delay(1000);
           delay(1000);
        if(read3 >=HIGH){
          else{
          // Entrada 1 y 0
           delay(1000);
           delay(1000);
        if(read3 >=HIGH){
          else{
          // Entrada 1 y 1
           delay(1000);
           delay(1000);
        if(read3 >=HIGH){
          else{
delay(1000);
        delay(500);
        delay(1000);
        if(read4 >=HIGH){
          myGLCD.fillRect(253,298,267,303);
          else{
          // Entrada 0 y 1
           delay(1000);
           delay(1000);
        if(read4 >=HIGH){
          else{
          // Entrada 1 y 0
           delay(1000);
           delay(1000);
        if(read4 >=HIGH){
          else{
          // Entrada 1 y 1
           delay(1000);
           delay(1000);
        if(read4 >=HIGH){
          else{
         if(ORstate == 12){
            myGLCD.print(" OK ",688,270);
          else{
    break;
case 3: // Ejecuta test a compuerta NOT
            // Entrada 0 en GATE 1
        delay(500);
        myGLCD.fillRect(59,364,69,368);
        myGLCD.print("0",615,100);
        delay(1000);
        read1 = digitalRead(out2);
        if(read1 ==HIGH){
          NOTstate = NOTstate +1;
          myGLCD.fillRect(114,364,122,368);
          myGLCD.fillRect(118,369,122,418);
          else{
          // Entrada 1 en GATE 1
           delay(1000);
           myGLCD.print("1",615,140);
           delay(1000);
          if(read1 ==HIGH){
          else{
        delay(1000);
               // Entrada 0 en GATE 2
        delay(500);
        myGLCD.fillRect(190,418,195,364);
        myGLCD.fillRect(196,364,210,369);
        digitalWrite(out3, LOW);
        delay(1000);
        read2 = digitalRead(out4);
        if(read2 ==HIGH){
          myGLCD.fillRect(257,364,267,369);
          myGLCD.fillRect(263,370,267,418);
          else{
          // Entrada 1 en GATE 2
           delay(1000);
           digitalWrite(out3, HIGH);
           delay(1000);
        if(read2 ==HIGH){
          else{
delay(1000);
          // Entrada 0 en GATE 3
        delay(500);
        myGLCD.fillRect(337,418,341,364);
        myGLCD.fillRect(342,364,355,368);
        delay(1000);
        read4 = digitalRead(out6);
        if(read4 ==HIGH){
          myGLCD.fillRect(400,364,415,368);
          myGLCD.fillRect(411,369,415,418);
          else{
          // Entrada 1 en GATE 3
           delay(1000);
           delay(1000);
        if(read4 ==HIGH){
          else{
delay(1000);
          // Entrada 0 en GATE 4
        delay(500);
        myGLCD.fillRect(412,254,417,301);
        myGLCD.fillRect(418,296,428,301);
        delay(1000);
        read4 = digitalRead(out7);
        if(read4 ==HIGH){
          myGLCD.fillRect(470,296,476,301);
          myGLCD.fillRect(471,295,476,254);
          else{
          // Entrada 1 en GATE 4
           delay(1000);
           delay(1000);
        if(read4 ==HIGH){
          else{
delay(1000);
          // Entrada 0 en GATE 5
        delay(500);
        myGLCD.print("GATE 5",577,260);
        myGLCD.fillRect(264,254,269,301);
        myGLCD.fillRect(270,296,285,301);
        digitalWrite(out10, LOW);
        delay(1000);
        read4 = digitalRead(out9);
        if(read4 ==HIGH){
          myGLCD.fillRect(328,296,336,301);
          myGLCD.fillRect(337,301,342,254);
          else{
          // Entrada 1 en GATE 5
           delay(1000);
           digitalWrite(out10, HIGH);
           delay(1000);
        if(read4 ==HIGH){
          else{
delay(1000);
          // Entrada 0 en GATE 6
        delay(500);
        myGLCD.print("GATE 6",577,260);
        myGLCD.fillRect(115,254,120,301);
        myGLCD.fillRect(121,296,135,301);
        delay(1000);
        read4 = digitalRead(out11);
        if(read4 ==HIGH){
          myGLCD.fillRect(177,296,190,301);
          myGLCD.fillRect(191,301,195,254);
          else{
          // Entrada 1 en GATE 6
           delay(1000);
           delay(1000);
        if(read4 ==HIGH){
          else{
         if(NOTstate == 12){
          else{
     break;
     case 5: // Ejecuta test a compuerta NAND
        delay(1000);
        if(read1 ==HIGH){
          NANDstate = NANDstate+1;
          else{
          // Entrada 0 y 1
           delay(1000);
           delay(1000);
        if(read1 ==HIGH){
          else{
          // Entrada 1 y 0
           delay(1000);
           delay(1000);
        if(read1 ==HIGH){
          else{
          // Entrada 1 y 1
           delay(1000);
           delay(1000);
        if(read1 ==HIGH){
          else{
          NANDstate = NANDstate + 1;
        delay(1000);
        delay(500);
        delay(1000);
        if(read2 ==HIGH){
          else{
          // Entrada 0 y 1
           delay(1000);
           delay(1000);
        if(read2 ==HIGH){
          else{
          // Entrada 1 y 0
           delay(1000);
           delay(1000);
        if(read2 ==HIGH){
          else{
          // Entrada 1 y 1
           delay(1000);
           delay(1000);
        if(read2 ==HIGH){
          else{
         delay(1000);
        delay(500);
        delay(1000);
        if(read3 ==HIGH){
          else{
          // Entrada 0 y 1
           delay(1000);
           delay(1000);
        if(read3 ==HIGH){
          else{
          // Entrada 1 y 0
           delay(1000);
           delay(1000);
        if(read3 ==HIGH){
          else{
          // Entrada 1 y 1
           delay(1000);
           delay(1000);
        if(read3 ==HIGH){
          else{
delay(1000);
        delay(500);
        delay(1000);
        if(read4 ==HIGH){
          else{
          // Entrada 0 y 1
           delay(1000);
           delay(1000);
        if(read4 ==HIGH){
          else{
          // Entrada 1 y 0
           delay(1000);
           delay(1000);
        if(read4 ==HIGH){
          else{
          // Entrada 1 y 1
           delay(1000);
           delay(1000);
        if(read4 ==HIGH){
          else{
          if(NANDstate == 16){
          else{
          Serial.print(NANDstate);
    break;
This is a new project in development, therefore, only the system can test AND, OR, NOT and NAND IC Gates. Soon I will update the Sketch with the functionality for the remaining gates.
