Amazon Alexa
HOW TO CREATE A 3D LOCK USING 3D MODELING SOFTWARE
July 31, 2022 by Simran Khuntia
In this tutorial article, we will be going through the steps of how to design a 3D lock in SelfCAD
In this tutorial article, we are 3D designing a lock in 3D modeling software. We will use captivating tools like move, 3D shapes, extrusion, and fillet to 3d design this lock. 3D modeling is utilised to make 3D models that can either be utilised in prototyping, representations, sensible renders and numerous others. By simply figuring out how to make a 3D lock, you will likewise get to know how to utilise the different tools of SelfCAD.
You can also visit our page and check our other such articles how to design a 3D headset stand.
So we should get everything rolling!
Step1: Insert a cylinder and select one of its circular faces
First of all, go to the 3D shapes and insert a cylinder to the working interface. Set top radius to 10, bottom radius to 10, height to 10, vertical segments to 32 and rotation z to 90. Then opt for polygon selection and select one of the circular faces of the cylinder.
Step2: Extrude the face, set operation and create copies
Next, go to modify and select the extrusion tool. Set the amount to 10. Then click on the add option in the macro step. Set operation to rotate, y to -5 and amount of copies to 12.
Step3: Extrude the face and insert a cube
Now, extrude the selected face to an amount of 50. Then insert a cube and set its height to 40, depth to 120, position x to 50 and position z to 40.
Step4: Fillet the edges
Next, we will opt for edge selection and select the longer edges of both the rear sided faces. Then select the fillet tool and set level to 5. After that, select mesh_4 and deselect mesh_8.
Step5: Move the handle and insert another cylinder
Now, go to the move tool and set y to 10 and z to 38.98. Then insert another cylinder and set its top radius to 20, bottom radius to 20, height to 30, vertical segments to 32, position x to 75, position y to 12, position z to 39.
Step6: Subtract the cylinders from the cube keeping the cylinder intact
Next, we will select mesh_8 and mesh_4 and go to stitch and scoop. Then from the tool panel we will choose the difference option and subtract mesh_4 and mesh_12 and click on the keep subtracted objects.
Step7: Insert another cube and subtract it from the cylinder
Now, insert another cube and set its width to 20, height to 10, depth to 5, position x to 75, position y to 32 and position z to 39. Then select mesh_12 and difference it with keeping mesh_16 to subtract.
Conclusion: Therefore, we have created a 3D lock using seven simple steps in SelfCAD
We have 3D designed a basic 3D lock utilising the different tools of SelfCAD. You can make various designs of such amazing relics using SelfCAD by following the above basic advances. After you are finished with 3D designing the model, you can likewise utilise the in-constructed slicer of SelfCAD to make it 3D printable by creating the G-Code that you can ship off your 3D printer.
